offset ? 15x8 wheel on crx - Honda-Tech
Closed Thread
Old 08-07-2006, 08:14 PM   #1
Rob.'s Avatar
Default offset ? 15x8 wheel on crx
Ok..Im seriously considering buying Work equip 03 in black with 15x8 rims with 2" deep lip.I just wanna know what offset I should get ? The car is a 1991 crx si.
I dont wanna order rims unless I know 100% that it will be ok.
I will be using 195/50 15 tires, so its gonna stretch a bit over the rim.
Right now I have 15x7 et 35 with no problems at all.
Here's some pics of a car with similar style wheels I want in 15x8.
Rob. is offline
Old 08-07-2006, 08:49 PM   #2
Default Re: offset ? 15x8 wheel on crx (Rob.)
responded to u in ur other thread brotha!!!
HeyMikeyyyy is offline
Old 08-07-2006, 10:43 PM   #3
H-T Order of Merit
195/50-15 tires - which are the correct 15" size for your car - can't be mounted on 15x8 wheels. They're too wide. You'll need wheels that are 5.5-7.0 inches wide.
nsxtasy is offline
Old 08-07-2006, 10:48 PM   #4
Rob.'s Avatar
Default Re: offset ? 15x8 wheel on crx (nsxtasy)
Quote:
says who ? you can stretch them ...
sicc 83 has the wheels (15x8 +13 offset)
+19 offset on my crx will work perfectly, but only +10 and +23 are offered with work equip 03 "0 disc" of the 2" deep lip...
Rob. is offline
Old 08-07-2006, 11:10 PM   #5
H-T Order of Merit
Quote:
Originally Posted by Rob.
says who ?
Says all the companies who manufacture the tires.
But go ahead, don't believe me. Just remember, they won't be warrantied and you won't be able to sue the manufacturers if you try mounting them on unapproved rim sizes and you can't mount them or you get a blowout. It's your risk (and there is absolutely ZERO benefit to using wheels that are too wide for the tires)...
nsxtasy is offline
Old 08-07-2006, 11:11 PM   #6
FalkenSiR's Avatar
Is there such thing as a "bad seal" when it comes to tires or not?
FalkenSiR is offline
Old 08-07-2006, 11:32 PM   #7
H-T Order of Merit
Default Re: offset ? 15x8 wheel on crx (fast95eg8)
Quote:
If the tire doesn't seat properly at the bead when it's mounted, then yes, it's possible that there is a bad seal. And this could easily happen when a tire is stretched beyond its design specifications, onto a wheel that is wider than approved by the manufacturer.
nsxtasy is offline
Old 08-08-2006, 02:21 AM   #8
i know plenty of vw guys who run 195s on 8 inch wheels no prob. even 205s on 9 inch wheels. it can be done....
to be safe id do 205 50s on the 8 inch wheels, there would still be a bit of stretch.
as for the wheels i think that the 23 offset equips would work but you may have to mess with rolling fenders, as well as ride hieght to get it perfect.
05member y0 is offline
Old 08-08-2006, 03:17 AM   #9
Moto-hashiriya's Avatar
Default Re: (05member y0)
What we do in here in Japan is make the fender work for the wheel/size you want
Moto-hashiriya is offline
Old 08-08-2006, 07:54 AM   #10
Rob.'s Avatar
Default Re: (Moto-hashiriya)
Quote:
ROFLMAO.
You guys take it to the extreme.
Rob. is offline
Old 08-08-2006, 08:07 AM   #11
Default Re: (Rob.)
ive seen a 15x9 wheels mounted on to a 195/50/15s in case HONDA TECH DIDNT KNO VW GUYS have been doing it forever Stretched tires ftw!!!
Old 08-11-2006, 09:23 AM   #12
hybridmoments's Avatar
Default Re: (HeyMikeyyyy)
just cause everyone in england and europe, and vw guys rock um that way doesn't mean it's beneficial
why don't you wanna run wider tires. typically more tread width can be a good thing.
and what kind of tires you going to run? spending $1600 plus dollars on rims and running some $40 195/50/15 . seems strange. plus with the rim hanging out so much you are going to be more likely to damage the rims.
hybridmoments is offline
Old 08-11-2006, 10:23 AM   #13
Default Re: (hybridmoments)
get atleast a 205 wide tire. dont try and stretch a 195 on an 8" rim. Yes people do it but people do a lot of stupid things
TurboEM1 is offline
Old 08-11-2006, 02:18 PM   #14
Screaming Vtec's Avatar
Default Re: (TurboEM1)
195 on an 8" isnt a stretch
Over here we do 195 on a 9.5" now thats a stretch..
Most of the drift boys stretch tyres, if its gonna come off, drifting is where its gonna come off...
195's on an 8" isnt unsafe
Screaming Vtec is offline
Old 08-11-2006, 04:41 PM   #15
H-T Order of Merit
Default Re: (Screaming Vtec)
Quote:
Absolutely not true.
So tell me - If his tire breaks the bead and he runs off the road, will YOU be paying for his damages?
But heck, you don't need to believe either one of us. Call up the customer service number for your tire's manufacturer, and ask them what's safe. Also ask them whether their tire warranty is applicable if the tire is mounted on rims wider than stated in their specification of approved rim widths. See what they say, and let us know. Then decide for yourself what to do.
nsxtasy is offline
Old 08-11-2006, 04:47 PM   #16
Earthworm Jim's Avatar
15*7.5 big dog
Earthworm Jim is offline
Old 08-12-2006, 03:28 PM   #17
Freshazzburu's Avatar
Default Re: offset ? 15x8 wheel on crx (Earthworm Jim)
What keeps a car on the road are the tires it rolls on. Tire manufactures would not say it's not safe if they didn't think it was not safe. As posted above, if anything, modify the fender rather than skimping on the tires (if 15x8 is a must).
This doesn't matter if the car is purely for show and will never be driven on the streets, in that case stretch away.
Freshazzburu is offline
Old 08-14-2006, 11:23 AM   #18
Sequoyah's Avatar
Quote:
:cues Vonage music: woo-hoo woo-hoo-hoo, woo-hoo woo-hoo-hoo.
To the OP...do whatever you want. Take pics of the aftermath
Sequoyah is offline
Old 08-14-2006, 11:24 AM   #19
TurboJesse
Guest
Posts: n/a
Default Re: offset ? 15x8 wheel on crx (Freshazzburu)
195/45/15 on 15x8 +25 offset...
Old 08-18-2006, 12:22 AM   #20
junk in the trunk's Avatar
Default Re: offset ? 15x8 wheel on crx (TurboJesse)
195's will be perfect on an 8" wheel **** i would rock 195's on a 9" wheel too
junk in the trunk is offline
Old 08-18-2006, 04:10 AM   #21
haha
NSXTASY
Stop being a *****
8" is only half an inch wider than the recommend widths for a 195 anyway, they have tolerances
If a tyre is recommended as being 'safe' on an 7.5" rim, you can guaratee that it will be safe on an 8"
Its your opinion thou at the end of the day, but in MY opinion. if a tyre stays on the rim at 120mph sideways, then it will stay on the rim for everyother eventuality
Old 08-18-2006, 06:33 AM   #22
H-T Order of Merit
Default Re: offset ? 15x8 wheel on crx (Screaming Vtec)
Stop being a *****
Stop being so ignorant.
Wrong. Most 195/50-15 tires are recommended only for use on rims 5.5-7.0 inches wide. That's a full inch off.
And if the tire doesn't stay on the rim at 120 mph, then you won't be posting here to tell us about it afterwards.
nsxtasy is offline
Old 08-18-2006, 06:59 PM   #23
old man neri's Avatar
Quote:
Originally Posted by 05member y0
i know plenty of vw guys who run 195s on 8 inch wheels no prob.......
Indeed, it seems to be a VW thing.
http://forums.vwvortex.com/zerothread?id=2234638
You might find info there. I don't recommend you do somethign that is not recommended by the manufacturer but read that, you might learn something.
Cheers.
old man neri is offline
Old 08-18-2006, 11:17 PM   #24
vtecsi00's Avatar
well now lets see a tire that that sits corectly on a 6.5 width wheel versus a tire that is going to stretched on a 8 inch wide wheel???? correct fitment for a 8 inch wide wheel would be 225/50r15 tire can you stretch a 195/50r15 tire yes do it all the time for vw boys at my shop is it correct no!!!
offset wise did you call works??????
vtecsi00 is offline
Old 08-19-2006, 06:48 AM   #25
efvader's Avatar
Quote:
haahaa thats funny right there
efvader is offline
Closed Thread
The EF sQuad Thread vega_ROCKS Group Threads 6702 12-06-2016 05:10 AM
Pics of my 91 Civic Hatch...the ShitBox DD Prelude_2_NV Honda / Acura 154 04-05-2011 12:43 PM
rim experts.... Rob. Honda / Acura 77 08-09-2006 06:01 AM
Keep my Gunmetal rims or go GOLD??? AlexLude Honda / Acura 61 05-12-2004 05:26 PM
One Pic of My 4g Lude Prelude_2_NV Honda / Acura 24 03-02-2003 09:07 PM
Tags
15x8, 195, 22550r15, crx, ef, honda, inch, offset, put, rim, rims, stretch, tires, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
