metal wires coming from tires?! help!! - Honda-Tech
Old 10-22-2007, 12:58 AM   #1
krayz3e's Avatar
Default metal wires coming from tires?! help!!
when i took off my wheels to lower my car, i found out that my wheels had metal wires coming out.. any ideas?! help!!
krayz3e is offline   Reply With Quote
Old 10-22-2007, 01:04 AM   #2
SilverDC4's Avatar
it's showing cord, means it's time to replace the tires
SilverDC4 is offline   Reply With Quote
Old 10-22-2007, 01:34 AM   #3
2ndlife's Avatar
Default Re: (SilverDC4)
You meant your tires had wires sticking out right? Yea that means your tires are long overdue to be changed. All the tread are gone and you should change them asap. After you lower the car, it's recommended to align it.
2ndlife is offline   Reply With Quote
Old 10-22-2007, 01:52 AM   #4
Doostur's Avatar
Default Re: (2ndlife)
Quote:
No daubt. I wouldn't even drive on them at all unless you have to - to go get new tires. All tires showing metal? How many miles are on them and what kind of tires? Same spot on all four? If your car lowered at all now or ever been with the suspension?
Doostur is offline   Reply With Quote
Old 10-22-2007, 11:56 PM   #5
krayz3e's Avatar
Default Re: metal wires coming from tires?! help!! (krayz3e)
i'm planning on getting tires tomorrow... the car is already lowered. im making it even lower... thanks for the info.
Old 10-23-2007, 01:44 AM   #6
Doostur's Avatar
Quote:
Originally Posted by krayz3e
[B]the car is already lowered. im making it even lower[/B
Make sure you get your camber fixed and alighment.
How to install your own aftermarket horn on EK!!! lcjarrett Honda Civic / Del Sol (1992 - 2000) 10 10-09-2006 11:33 AM
Help with Accord Popper Storm_Rider Honda Prelude 1 01-27-2006 06:48 PM
Metal on metal noise near wheels? Kirk@SyndromeAuto Acura Integra 12 02-14-2005 06:42 PM
Help loud grinding noise! SD99GSR Acura Integra 3 07-17-2003 06:55 PM
metal on metal sound carl_aka_carlos Acura Integra 15 07-09-2002 01:57 AM
Tags
car, coming, drive, krayz3e, metal, poking, showing, steel, sticking, thread, threads, tire, tires, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
