Lugnuts for 05 hubcaps
I bought a set of 15'' steelies off a 2005 civic to use as the street wheels on my 92 CX and the seller threw in the hubcaps. I know they require a lugnut with a washer but the OEM 2005 lug nuts from honda are stupid expensive, like $6 /each. Anyone know where I can get cheap lugnuts that will do the job?
Found a set on Ebay. It's crazy that their aren't any readily avaliable aftermarket options considering how many millions of hondas have come with hubcaps and the same lug pattern for 20+ years.
Sanji
Re: Lugnuts for 05 hubcaps
You will need a set of ball-seat lug nuts for those steelies. Conical-seat lug nuts won't work properly/safely (and they're the most common aftermarket lug nut out there). I don't know what "lug nut with a washer" you're referring to, though. They don't require any washer.
I know.
A nylon washer is required to hold the hubcap in place. The specific nut necessary has a groove in which this washer is placed.
As well as being a ball seat.
