How do I get paint off of my tires??? - Honda-Tech
Old 04-22-2008, 11:09 PM   #1
starbai's Avatar
Default How do I get paint off of my tires???
Thanks for the tips and site suggestions. I used the DIY in this forum to refinish my rims on the prelude this weekend.
It worked out well except I couldn't tape off the tire beacuse nothing would stick to it. (tape or otherwise)
so I made a template out of cardboard and just put it over the tire with a hole for the rim which I sprayed through the hole.
Problem is now I have over spray on the tires.
Can anyone suggest a way to remove paint from teh tires that wont do any long term damage to the tires?
Thanks
starbai is offline   Reply With Quote
Old 04-22-2008, 11:57 PM   #2
Royal_C!ty's Avatar
Default Re: How do I get paint off of my tires??? (starbai)
hmm... i've always wondered this myself
Royal_C!ty is offline   Reply With Quote
Old 04-23-2008, 12:30 AM   #3
jdm_dc_fan's Avatar
Location: "That one guy with that one car" Kennewick WA
if its only a little overspray you can go over it with sandpaper and should rub off as easy as fake tattoo that would come in those gum packets back in the day. hhmmm...
jdm_dc_fan is offline   Reply With Quote
Old 04-23-2008, 12:39 PM   #4
starbai's Avatar
Default Re: (jdm_dc_fan)
hmmm
might be a little more than "a little"
I was considering useing some of the acetone I used to clean the wheel in the first place... anyone know if that would do any long term damage on the tires?
Old 04-23-2008, 08:09 PM   #5
mtsepulveda85's Avatar
Default Re: (starbai)
yea i was gonna say sandpaper or maybe a wire brush
mtsepulveda85 is offline   Reply With Quote
Old 04-23-2008, 08:13 PM   #6
GDD GRAMMAR POLICE
PhantoM.DA's Avatar
Default Re: (mtsepulveda85)
paint thinner, put some on a rag and just rub it off, ive used this many times when getting paint on my tires.
PhantoM.DA is offline   Reply With Quote
Old 04-23-2008, 10:27 PM   #7
starbai's Avatar
and the paint thinner doesn't adversely affect the tires? I've read that it can soften the rubber compound and can make the tires dangerous.
guess if u've done it several times its ok. but jus figured i'd throw that out there.
Old 04-23-2008, 10:34 PM   #8
GDD GRAMMAR POLICE
PhantoM.DA's Avatar
I did it a few times on different tires, nothing happened. Just dont go crazy with the paint thinner and pour it all over the tire.
I can take a picture of my sidewall that i used a lot of the thinner on and show you its fine. And its probably been about a few months since i did it, everything looks/feels fine.
Old 04-23-2008, 11:57 PM   #9
Default Re: (PhantoM.DA)
i usually just sand it off considering it was only a small amount
r.wright is offline   Reply With Quote
Old 04-24-2008, 11:01 AM   #10
purejdmek9's Avatar
paint thinner works the best it will not affect your tires even the aircraft remover used to remove the wheel paint won't hurt your tires
purejdmek9 is offline   Reply With Quote
spray on spray off rim/tire cleaner? buymesomedunks Wheel and Tire 2 11-26-2010 08:29 AM
Aircraft paint stripper question.. hybrid90 Wheel and Tire 3 07-16-2008 04:45 PM
The 80 dollar DIY paint job. Hella good. Hazem Honda / Acura 39 03-02-2007 02:53 AM
prepping my car for paint, need some help JonnySBeee... Welding / Fabrication 16 07-26-2006 02:27 PM
How do I get wheel paint off tires? alfaaay Honda / Acura 9 03-26-2003 12:14 PM
Tags
acetone, civic, clean, hondatech, ig, overspray, paint, poured, prelude, remove, rims, tattooing, thinner, tires, tyres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
