Has anyone tried Lotus Exige wheels?
Has anyone tried Lotus Exige wheels(either oem or aftermarket)? These wheels are 4x100 with offsets between 27mm and 32mm.
So if I run 10mm or 15mm spacers on an EK, then they should fit. Does that seem right?
Re: Has anyone tried Lotus Exige wheels?
if the wheel is already 27mm offset and you added a 10mm spacer it will bring the wheels OUT 10mm meaning the offset will be like a 17mm offset wheel.
i found this :
http://www.sandsmuseum.com/cars/elis...up/wheels.html
looks like the center bore will work but then the stagger might be kinda weird unless you found 4 fronts. offset is okay already..not too crazy
i found this :
i found this :
i found this :
sk898
12-18-2002 02:22 PM
