Hankook Ventus RS-2 Z212
Old 03-14-2005, 09:05 AM
Chris@Tires.com's Avatar
Default Hankook Ventus RS-2 Z212
205/50R15 IN STOCK!!!! $78 a piece!!!
http://www.hankooktireusa.com/...tID=5
Old 03-15-2005, 07:19 AM
Default Re: Hankook Ventus RS-2 Z212 (Chris@Tires.com)
Old 03-15-2005, 05:12 PM
_BEN_'s Avatar
They kinda look like advans.
I bet this will be a hot tire.
I asked about these yesterday. Wasn't sure if they were new or not. I guess they are.
https://honda-tech.com/zerothread?id=1179478
Old 03-18-2005, 11:09 AM
EtherGhost's Avatar
Default Re: Hankook Ventus RS-2 Z212 (_BEN_)
Here are some pictures. It's still snowing outside, so no reviews yet
Old 03-18-2005, 08:54 PM
jdmgoldcivic's Avatar
Are these tires comparable with the azenis 215. How do they handle rain
Old 03-23-2005, 09:47 AM
JeremyL's Avatar
Default Re: Hankook Ventus RS-2 Z212 (jdmgoldcivic)
just by looking at the amount of rubber taken out for the circumfrential grooves i would have to think its not gonna be the same total dry grip as an Azenis but it looks like it would handle water a lot better
Old 03-23-2005, 06:15 PM
sohcSUCKS's Avatar
Default Re: Hankook Ventus RS-2 Z212 (JeremyL)
doesnt look verygood for rain, no drainage paths
Old 03-25-2005, 02:28 AM
JeremyL's Avatar
Default Re: Hankook Ventus RS-2 Z212 (sohcSUCKS)
no drainage paths? look at the tire again it has 4 cirumfrential grooves and sipes on the shoulder that go right out to the edge
Old 03-25-2005, 06:10 AM
Drainage paths?
The water flows through the circumferential grooves, just look at a Michelin PS2.
Old 03-25-2005, 06:43 AM
_BEN_'s Avatar
Bump for reviews.
Old 03-25-2005, 02:55 PM
onePOINTsix's Avatar
i was going to get these insted of Azines ST-215s but my friend had a set of azines localy so i got them insted. i'll get these next time
Old 03-28-2005, 10:12 AM
EtherGhost's Avatar
Default Re: Hankook Ventus RS-2 Z212 (onePOINTsix)
After driving these tires for about 50 miles, I have some initial observations. Going from stock Michelin Energy MXV4 195/60 R15 to the Hankooks, there is some more steering effort required, and some tracking of grooves in the street. They hum noticeably on concrete, but I heard on another forum that this should go away after 300 miles or so. They do seem to grip very well. They tend to pick up gravel and sand and throw it into my fenderwells. Going back to the Michelins I felt like I was in a luxury car compared to the Hankooks, road bumps were much smoother. I am not sure if this is because of the lower profile, or if the sidewalls are stiffer. I'll do another update later.
Old 04-01-2005, 02:28 PM
InfamousGSR's Avatar
Default Re: Hankook Ventus RS-2 Z212 (EtherGhost)
bump, i want to know too.
Old 04-05-2005, 04:48 PM
kineticgsr's Avatar
Default Re: Hankook Ventus RS-2 Z212 (InfamousGSR)
HERE IS OUR TECH GUYS THOUGHTS ON THE NEW HANKOOK
He his a national level Auto-x driver, his car was on the 05 Grassroots calander
Jeremy,
I ran the tires at our local event this last Sunday. I should have a better idea of how they work after another event or so. So far, I am running lower pressures than I did in the KD's, the grip was much better by my third run. the tires were at 160F after the last run and did not feel like they were giving up at all. I finished #1 overall for the event so they can't be that bad. The "Petal" shape of the tread blocks does not feather at all, it was really cool I thought....
Joshua Sortor
Technical Applications Specialist
Discount Tire Company
Old 04-05-2005, 09:01 PM
baonest's Avatar
hmm.. its either these, or the 615s
Old 04-06-2005, 07:54 AM
xjohnx's Avatar
Default Re: (baonest)
I know of a couple autocrossers who did a comparison test of the 215s v. 615s v. 212's. the 615's were about 7 tenths faster than the 215s on a 60 second course, and much more tolerant to heat than the old 215's were. The Hankooks were faster than the 615's by another 2 tenths. Looks like the way to go.
Old 04-06-2005, 08:55 AM
Mikes01GSR's Avatar
Default Re: (xjohnx)
I ordered a set of Z212's off of Chris in the the 215/45/16 size, I will be giving a review after I recieve and install them.
Old 04-06-2005, 09:20 PM
_BEN_'s Avatar
Default Re: (Mikes01GSR)
This tire will probably be HT's new azenis. But better.
Resonably priced.
Good performance
Comes in 215/45/16 and 205/50/15
ZR rated
Looks like it will do better in the rain. But the question is if it will do better in dry conditions.
And how long they will last.
Looking foward to more reviews.
Old 04-08-2005, 09:29 AM
whatcivic's Avatar
Default Re: (_BEN_)
bump! any more reviews?
Old 04-08-2005, 08:07 PM
G3NR8's Avatar
Default Re: (whatcivic)
Bump for more info....The new azenis are kinda pricey....I might go with these
Old 04-09-2005, 12:26 AM
h46it's Avatar
Default Re: (G3NR8)
Here's some more reviews on SCCA forum. Check it out:
http://www.sccaforums.com/ubb/...2/884
Old 04-11-2005, 11:48 AM
slowata's Avatar
Default Re: (h46it)
I am ordering a set today, will have them on by this weekend and I'll be able to give some reports
Ben
*edit* Nevermind on the Hankook's, couldn't get them anywhere close to the timeframe that I need them in. Looks like I'm stuck with ES100's this time around
Modified by neonorific20 at 2:14 PM 4/11/2005
Old 04-11-2005, 03:11 PM
h46it's Avatar
Default Re: (neonorific20)
What's the time frame on the Hankook's?
Old 04-11-2005, 06:21 PM
631 Teggy's Avatar
Default Re: (h46it)
It says they are out of stock on discounttiredirect.com
Old 04-11-2005, 07:36 PM
slowata's Avatar
Default Re: (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">It says they are out of stock on discounttiredirect.com</TD></TR></TABLE>
That's where I tried, and the guy said it'd be about a month until they could get them shipped, and I need tires this weekend
Ben
Quick Reply: Hankook Ventus RS-2 Z212
