Fitment Advice, Cragar Wheels, Bigger Tires
I currently have a 2000 Honda CR-V with the factory 15x6 wheels with standard 205/70R15 tires. I want to put a set of Cragar D Window or Soft 8's on that are 15x7. In addition I want to increase the tire size to 215/75R15. I want to do this without lifting it. From research I've done it seems the tires won't be an issue on the factory wheels but I need help choosing the correct offset for the wheels or if spacers are needed. I've been search for at least two hours but with so many numbers I have a headache and I'm terrible with numbers. Hopefully someone with great knowledge of offsets and numbers can easily help me move forward with what "should" fit.
Thanks so much!
Thanks so much!
-Intl Steve Krew
Re: Fitment Advice, Cragar Wheels, Bigger Tires
You'll need a 3-5mm spacer to clear the front caliper.
Without lifting, you may rub on the front fenders in a full lock turn.
For the rear you may rub if you fully compress the suspension and stuff the wheel in the well.
I believe that's about it. Check the 'lifted/off-road CR-V thread' in the CR-V forum for pics/info. It's a lot of pages but well worth it.
-Intl Steve Krew
The only way to run them is have a flat hub on the axle (like a rear drum) or you have to run a spacer to clear the brake caliper.
Think off-road Jeep wheels, which they essentially are.
Sanji
The only problem with that is you can't find crager wheels with a +25 due to the design. The face of the wheel is flat, it's a stamped wheel, not machined.
YodaIsGod
14
04-08-2003 03:18 PM
