97 Civic tire fit question
Old 12-31-2011, 10:17 AM
6gen's Avatar
Default 97 Civic tire fit question
I am replacing my 205/55 15 Nitto Neogens but haven't been able to find a replacement in the same tire size. I am concerned that 205/65 15 will rub. My vehicle is a completely stock 97 Civic with 2000 si alloy 15s. If those tires aren't going to work, what is the max tire size I can use without alteration? Will I need to step back down to a 195 width to increase diameter? Any info that will relieve my anxiety of buying the larger tires will be appreciated. Thanks
Old 12-31-2011, 10:46 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 97 Civic tire fit question
Where are you looking? Found 140 different matches for this tire size on Ebay alone.
Old 12-31-2011, 11:18 AM
6gen's Avatar
Discounttiredirect.com and tirerack.com mostly. I shop there so I can read reviews and comments. I should say I haven't found many tires that size that I like. The Neogens I have perform as long as there is no snow or ice, I'd like a true all season tire. Also looking for something with better treadlife. The Hankook Optimo H727 looks like an inexpensive option but now I am trying to find out which tire size is right for me.
Old 12-31-2011, 11:24 AM
The Grumpiest
Originally Posted by 6gen
I...haven't been able to find a replacement in the same tire size.
The Yokohama S-Drives are more than a suitable replacement. I run these. Direzzas have been reported to be a capable tire.
Old 12-31-2011, 11:38 AM
6gen's Avatar
Nice. I believe I read an article early on in my search that gave negative reviews for Direzzas but I like the S-Drives. What size do you use? Are you suggesting I give up the search for a different tire size all together and get whatever I can in the 205/55 15?
Old 12-31-2011, 01:02 PM
The Grumpiest
I run 16s.
You can get the S-Drives in that size.
http://www.ebay.com/itm/4-NEW-Yokoha...item43ac1356f9
Old 12-31-2011, 02:38 PM
Sanji
toyomatt84's Avatar
What model Direzza are you referring to? The DZ101's and D1 Star Spec's are both very good performing tires. I've had both.
Old 12-31-2011, 03:51 PM
Master Detailer
98civdx's Avatar
What about runing a 205-50-15?
Old 01-03-2012, 02:47 PM
doc@tirerack's Avatar
We recommend 205/50R15 for your model year to keep the overall tire diameter close to stock (23" overall), the year 2000 Civic used 195/55R15 as OE, so the 205/50R15 would be fine on that car as well.
Old 01-07-2012, 01:28 PM
6gen's Avatar
DZ101s. The Z1s are out of my price range for the moment.
Old 01-07-2012, 09:14 PM
Sanji
toyomatt84's Avatar
I've still got my Z101's. They're fantastic tires, in my personal opinion.
Old 01-08-2012, 11:03 AM
Blackhorizon_1's Avatar
Go to treadepot.com , they have a bunch of different tires in plenty of sizes. That's where I buy my tires, usually get them cheaper than anywhere else.
Hondacivic90ed
11-12-2007 06:45 AM
ek4__
02-21-2007 07:15 PM
hott-nix
07-13-2004 11:53 AM
stu2211
03-17-2003 09:42 PM
markchillin
06-20-2002 10:07 PM
Quick Reply: 97 Civic tire fit question
