14 inch rims on a DC2? Will they fit? - Honda-Tech
Old 05-04-2012, 04:01 PM   #1
Default 14 inch rims on a DC2? Will they fit?
I have a 94 GSR and I am trying to decide if I want to trade my Blades for a set of nice Enkei 92's. I was wondering if 14 inch rims were too small for my fronts? I know the GSR's have big brakes in the front and I'm concered they will rub. I've been trying to research this on my own but I cant seem to find the info I'm looking for!
Take me to school fellas!
froman09 is offline   Reply With Quote
Old 05-04-2012, 07:10 PM   #2
ek4serge's Avatar
Default Re: 14 inch rims on a DC2? Will they fit?
Whats the offset on those ,you can clear them within 5 millimeter spacer. I don't know why you'd want to go from 15's to 14s
ek4serge is offline   Reply With Quote
Old 05-08-2012, 01:34 PM   #3
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Wrong!!! Gsr brakes are the same as any other DC teg less the Type R.
I can fit 13" rota RB's over teg brakes with no problems so it is possible. Just measure the inside barrel of the rim or ask who ever you plan on purchasing from.
speedjunkie_g35 is offline   Reply With Quote
Old 05-08-2012, 03:42 PM   #4
4DRTEG210's Avatar
When I bought my DB they came with stock 14inch steel wheels and from what I notice they had to grind the caliper a lil to make it fit.
4DRTEG210 is offline   Reply With Quote
Old 05-09-2012, 01:36 AM   #5
UnleashedEJ1's Avatar
^^^If it was a stock steel wheel they didn't grind off anything to fit! Many integras came with a 14" wheel, alloy or steel. And like posted before the gsr has the same size brakes as the other models. It will most likely fit, throw them on and check fitment if you can.
UnleashedEJ1 is offline   Reply With Quote
Old 05-14-2012, 05:37 PM   #6
yes I had 14 inch steelies on my integra. Not an issue... I would personally stick with 15's at least
flycivicsi is offline   Reply With Quote
Old 05-14-2012, 05:43 PM   #7
furious94ls's Avatar
Stick with 15's but yes Honda/Acura 14's fit.
furious94ls is offline   Reply With Quote
Old 05-14-2012, 05:45 PM   #8
been there done that
doood's Avatar
my brother had 14x6 miata wheels on his old gsr. only modifications needed were to bore the center bore out a little to fit.
doood is offline   Reply With Quote
Old 05-15-2012, 04:30 PM   #9
H-T Platinum Sponsor
we've done 14x6 ET45 for snow tire use with no problems. Depending on the design of the wheel the offsets will range between 36mm to 45mm. All the "new" Enkei 92's I can get are all 15" diameter, so not sure what the specs would be on the 14" wheel
__________________
Doc@tirerack.com
800-428-8355, ext 665
Help support the forum !
Reference >Honda-Tech / Doc< when ordering online !
doc@tirerack is offline   Reply With Quote
4 lug OEM 17 inch alloy wheels? 342kcivic Wheel and Tire 5 07-07-2012 08:12 AM
wtb: 14inch steelies for DC teg in mke scobaru Mid-West (Sales) 5 09-19-2007 06:39 PM
Question about rims to use with slicks I just bought MikeNice Drag Racing 4 11-16-2005 02:48 AM
Difference between 2003 style si rims off a 2003 civic ex and the original 2000 si rims 94LSTEG Honda Civic / Del Sol (1992 - 2000) 10 05-09-2004 12:39 AM
Pics of stock GSR rims Jason W Honda / Acura 4 01-27-2002 07:35 PM
Tags
14, 14in, 92, civic, crv, dc2, enkei, fit, gsr, inch, powered, rims, steelies
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
