Worst Fabrication Pictures
#251
Re: (95delsolz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95delsolz6 »</TD></TR><TR><TD CLASS="quote">
You can't just walk up to a random welder and be good to go with a preset tune. </TD></TR></TABLE>
i know you cant, your the one who just said before that if you get the machine set up right your welds will turn out fine. thats not the case at all. thank you for just proving MY point. trust me i have worked in a metal fab shop for the past 6 years. some of the guys i work with and i will mess with eachother while we are in the middle of welding all the time.... we always walk up behind eachother while that person is welding and mess with their wire speed and crank the heat up or down during their weld and we have to continue the weld we cant stop in the middle of it... so do u see my point... "setting up the machine right" has nothing to do with a quality weld.... even if your dials are all messed up it is possible to still lay down a quality weld, if you yourself are a quality welder, you just have to know what your doing. im sorry but people like you who thinks welding is so easy really bother me... it takes much more than "5 minutes" to be a quality welder.
is there any other REAL welders reading this right now that can help me out with this dude???
Modified by Eg2Love at 10:44 AM 9/18/2008
#252
Re: (95delsolz6)
Personal experience tells me otherwise. You can't just walk up to a random welder and be good to go with a preset tune. That's like saying a random basemap for an ecu will work for a particular engine. </TD></TR></TABLE>
you're changing your argument all over the place.
i just did this last night,
was teaching someone how to stick weld, 6010 1/8".
i set the machine up. laid down a ew passes, came out fine. threw the scrap away.
got a fresh piece, ew box of rods. handed it over telling them the genral whip technique, and how to start an arc.
they had travel speed, and arc length off. another pass just cut into the plate.
i set the machine up, perfectly. and welds werent coming out great.
perfect example.
perfect example.
#253
Re: (i drive a honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i drive a honda »</TD></TR><TR><TD CLASS="quote">
perfect example. </TD></TR></TABLE>
THANK YOU VERY MUCH! i appreciate the help.
#256
OK I've been MIG welding for about 6 months now, so I'm no pro by any means. I'm certainly not saying welding is easy either. It's not. but I can't even imagine welding something like that. The first bead I ever ran in my life didn't look like that. I mean anyone with about half an IQ can look at that and say "I've never seen any weld on anything anywhere that looks like this. Maybe I should try again." I don't even know HOW I could make a weld look like that. I am absolutely dumbfounded by this.
#257
Re: (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller »</TD></TR><TR><TD CLASS="quote">OK I've been MIG welding for about 6 months now, so I'm no pro by any means. I'm certainly not saying welding is easy either. It's not. but I can't even imagine welding something like that. The first bead I ever ran in my life didn't look like that. I mean anyone with about half an IQ can look at that and say "I've never seen any weld on anything anywhere that looks like this. Maybe I should try again." I don't even know HOW I could make a weld look like that. I am absolutely dumbfounded by this. </TD></TR></TABLE>
apprently you need to use the full spool
#258
Make mine whatever you want
forget robotic tig welders, full-race should hire that kid. I'm actually VERY interested to see how much of a difference there would be with that pos.
#260
Re: (srmofo)
haha, those pictures have floated around for a while now. Can you imagine how miserable that would be inside there with all of the leaking exhaust parts.... . Natural Selection
#263
Re: (Nick Z32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick Z32 »</TD></TR><TR><TD CLASS="quote">ok, thouse ARE mustang wheels arnt they
wow</TD></TR></TABLE>
yes, and they are far and away the best part of the car.
I don't understand how that even works. I mean, obviously it doesn't, or at least very well, but WTF, is there another motor in the back seat?
Rube Goldberg would be proud!
#264
Re: (jweller)
on the MAXima, what are those pictured in passenger seat?? those arent the turbos. are they?? im so confused!! they look like theres oil lines but all i think i see is 2 tiny compressors
#265
Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">
i've made turds that have smoother transitions that that.</TD></TR></TABLE>
The part I don't understand there is why he didn't just go for a log manifold. Logs aren't the greatest, but they are totally adequate into the 400 HP area and are at least as easy to build as that awful thing.
Oh, and 1/8" plate FTW on the turbine flange. That'll seal.
#271
Re: (G2turbo_terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2turbo_terror »</TD></TR><TR><TD CLASS="quote">You are correct. Its all scrap metal (obviously) and galvanized fence post. Very entertaining.</TD></TR></TABLE>
Galvanized tubing you say. Sounds like fun. Wonder if he got metal fume fever from that joke.
#273
That wouldn't flow too bad.....
But seriously, I've seen worse factory turbo manifold hack jobs. A buddy of mine made this, and to make things worse the T25 he used didn't have the proper sized fittings, but used JB Weld to make it seal (?).
#274
dude, if someone made that better, and stashed the turbo out of sight,
thrwe the charge piping/ bov in the stcok intacke ducting
painted the fmic black.
you'd havea car full of win </TD></TR></TABLE> It's been done by another guy on HMT. The car was in SCC for it a few years ago. It was stealthy as hell.
