will aircraft paint remover dissolve fiberglass? - Honda-Tech
Old 06-22-2005, 01:14 AM   #1
deadlock32's Avatar
Default will aircraft paint remover dissolve fiberglass?
Just a simple question. I just want to get rid of the paint on som fiberglass and instead of talking all the time to sand it off, can I use paint remover? I am just wondering if it will start to dissolve the fiberglass along with the paint. = ]
thanks in advance.
deadlock32 is offline   Reply With Quote
Old 06-22-2005, 08:11 AM   #2
Flashmn's Avatar
Default Re: will aircraft paint remover dissolve fiberglass? (deadlock32)
I doubt it would, but I'd say you'd get a much better result and a better surface to respray on when you sand it. Dont do it by hand tho
Flashmn is offline   Reply With Quote
Old 06-22-2005, 07:36 PM   #3
deadlock32's Avatar
Default Re: will aircraft paint remover dissolve fiberglass? (Flashmn)
Quote:
well, i will be laying down some new fiberglass and such, and im not opposed to sanding it, but it will take a lot more time to sand off the existing paint rather than taking off the paint then sanding it smooth.
Old 06-23-2005, 11:19 AM   #4
underpressure02's Avatar
I am pretty sure you will be okay. I think I used aircraft paint remover when my dad and I did the frame up on the 68 vette. I would have to check what we used.
underpressure02 is offline   Reply With Quote
Old 06-24-2005, 11:22 AM   #5
turbo_b16_ex's Avatar
i would recommend testing it out on a corvette and see what happens. Who here actually likes ls1's?
turbo_b16_ex is offline   Reply With Quote
Old 06-25-2005, 07:03 PM   #6
rioninja's Avatar
If your quick about it, you'll be ok. But leave it on there too long, and it will definatly start eroding the resin.
rioninja is offline   Reply With Quote
Old 06-26-2005, 04:50 AM   #7
NitroSign's Avatar
it dissolves body filler in a heartbeat. ive done it before by accident! it turns to mush
NitroSign is offline   Reply With Quote
Old 06-26-2005, 08:53 AM   #8
alexb16hb's Avatar
Default Re: (NitroSign)
That stuff will make fiberglass start to get soft and mushy!! I wouldnt do it!!
alexb16hb is offline   Reply With Quote
removing interior tar and caulking vandersmissenc Honda Civic / Del Sol (1992 - 2000) 1 12-10-2006 04:40 PM
Tar Stuck on the Rims!!! Help EpicTypeR Acura Integra Type-R 4 05-31-2004 03:04 AM
paint chips fugaziman Acura Integra 3 09-28-2003 12:08 PM
anyone work at a bodyshop? help me!! GeeSaRe Honda Prelude 3 06-19-2001 07:23 AM
any1 work in an AUTO BODYSHOP? please help GeeSaRe Honda Civic / Del Sol (1992 - 2000) 1 06-18-2001 02:57 PM
Tags
aircraft, airplane, body, disolve, dissolve, dissolves, dont, fiberglass, filler, motorcycles, paint, prep, remove, remover, stripper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
