welding t3 flange on t25 flanged ram horn
Old 05-13-2010, 11:03 AM
JDMgsrTeg08's Avatar
Default welding t3 flange on t25 flanged ram horn
Im looking to buy a ram horn turbo manifold which has a t25 flange on it. My turbo is a t3/t4 50 trim. Is it that big of a deal to weld a t3 flange on it? Will it be just as reliable and everything? And will it be worth it? Or should i just wait and find one thats t3 flanged already?
Old 05-13-2010, 11:32 AM
GTibunny16v's Avatar
Default Re: welding t3 flange on t25 flanged ram horn
If it has a 4" collector you can probably just trim down the collector a bit to a t3 flange opening. This manifold is made to fit a smaller compressor housing, gotta take that into consideration also. Truthfully, Id just get a manifold thats built for a T3/T4.
Old 05-13-2010, 03:05 PM
RC000E's Avatar
It'll be fine to trim as long as you don't get into interference with the wastegate opening. If they drilled the opening right at the flange, then when you trim up, your gonna have to recut the wastegate and have that moved....could turn into a b*tch or a lot of work.
Old 05-14-2010, 09:01 PM
Ok thanks guys. im gonna pass on it for now. I'll probably just wait for when Synapse has a sale and pick one up from them.
FlyNLow1987
03-08-2014 05:40 AM
BOOSTEDk24a4
06-25-2007 09:51 AM
ITS_Dunn
02-01-2006 07:29 PM
BlueLude94
10-31-2005 07:39 AM
servion
10-01-2002 11:56 AM
Quick Reply: welding t3 flange on t25 flanged ram horn
