welding of a down pipe exhaust
Old 04-02-2005, 11:55 PM
reed857's Avatar
Default welding of a down pipe exhaust
whats up guys. well I have a prob I went and changed my oil the other day on a lift.when I went to wipe down my oil pan a little bit I noticed all this black **** so I was like ummm. where is that from. look alittle further and I see a crack in my down pipe exhaust. now its a drag III cast iron down pipe. my main question is if it can be welded. and if it can any suggestions on what to use. hit me back. thanks. Jon
Old 04-03-2005, 05:52 AM
NJIN BUILDR's Avatar
Default Re: welding of a down pipe exhaust (reed857)
Yes,cast iron can be welded.It needs to be preheated before welding and cooled down slowly to keep from cracking it more.Many pro welding shops can handle it.
Glenn
Old 04-03-2005, 09:15 AM
reed857's Avatar
sounds good man thanks for the good advice
Old 04-03-2005, 10:15 AM
Canuk_SiR's Avatar
are you sure its cast? I thought only the manifold was cast, and the dp was stainless tube
Old 04-04-2005, 11:45 AM
asylumxl's Avatar
Default Re: welding of a down pipe exhaust (Canuk_SiR)
i thought the same - also wouldn't making an exhaust out of a cast be extremely unprofitable
trancend
Welding / Fabrication
18
10-10-2013 05:03 PM
1SlowSi
03-28-2005 01:55 PM
tgrace
08-22-2003 09:10 AM
Quick Reply: welding of a down pipe exhaust
