welding aluminum wheel crack? - Honda-Tech
Old 07-17-2009, 03:57 PM   #1
garados's Avatar
Default welding aluminum wheel crack?
I have an aluminum wheel that cracked at the outer lip, probably a half inch into the wheel from the lip. Would it be possible to have a standard tig weld done to fix this, or would it have to be re-heat treated to keep the integrity of the wheel?
garados is offline   Reply With Quote
Old 07-17-2009, 04:07 PM   #2
boost_aholic97's Avatar
Default Re: welding aluminum wheel crack?
i have seen people just preheat and weld and they hold up just fine, but then again many people have come to me to weld stuff like this and i dont touch it, cause of liability issues....but it can be done.
boost_aholic97 is offline   Reply With Quote
Old 07-17-2009, 04:28 PM   #3
srmofo's Avatar
Ive seen it done. just make sure the person is competent enough to do it....also the wheel is usually pretty bent if it was hit hard enough to crack it
srmofo is offline   Reply With Quote
Old 07-17-2009, 05:06 PM   #4
Kevin's Avatar
Try to find a local wheel repair shop and let them work their magic. I've seen OEM style wheels repaired and were perfectly fine.
Kevin is offline   Reply With Quote
Old 07-18-2009, 03:29 AM   #5
RickyLee53's Avatar
Quote:
The wheel repair shops I've seen either send their wheels to a "welder" to be repaired, they do the finishing off etc but don't actually do the welding.
Most specialist welders IMO would do a better job as they do this type of thing day in day out. Rather than repairing wheels and the odd 2" of weld here and there.
Obviously keep a close eye on it afterwards.
RickyLee53 is offline   Reply With Quote
Old 07-18-2009, 09:08 AM   #6
d16sandrail's Avatar
I've welded three cracked/broken aluminum wheels. Depending on where the cracked area is, it may or may not need pre heated (depends on the thickness). I don't really buy into all that liability crap, I won't take the job if I am not 110% confident in my ability, and that the customer will not have any future headaches with the results. Long story short, Yes it can be done, I would take it to a reputable welder (not a rim repair shop) the price will be a lot more at the rim repair shop because it is a specialty shop and they gotta make they're money somehow.
d16sandrail is offline   Reply With Quote
Old 07-18-2009, 09:24 AM   #7
jlude90's Avatar
yeah, i had an fn01-r with a good 2 inch crack in it, took it to my friend who TIGs for a living and i got it back with what looked like all the paint ground off of a perfect wheel. not distortion, not bent, nothing. threw some paint on it and i can't tell which wheel was fixed, this was about 3 years ago now.
wll wheels balance out well too, so i can't tell there either
jlude90 is offline   Reply With Quote
Old 07-18-2009, 10:42 AM   #8
Wopsicle69's Avatar
I had this problem with an Enkei RP01 rim. I removed maybe an 1/8" of material around the crack, drilled a hole at the end of the crack so it would not continue to crack, used a small propane torch to warm the aluminum up, hit it with the tig, used some filler to replace the material I grinded away, grinded the weld flat, threw on some silver paint, and havent had a problem with it since 2 years ago.
Wopsicle69 is offline   Reply With Quote
Old 07-19-2009, 06:34 PM   #9
garados's Avatar
Cool, thanks for the info guys!
Old 07-20-2009, 06:43 AM   #10
chrisbmx68's Avatar
I would agree that it can be done, just make sure you preheat it well, and let it cool slowly, and vee out the crack for maximum penetration. Drilling the ends of the crack is a good idea as well or it will probably just continue to crack after its welded.
chrisbmx68 is offline   Reply With Quote
Old 07-20-2009, 01:00 PM   #11
CVC9216's Avatar
I've welded probably 100+ wheels. The only ones that re-cracked (maybe a handfull) usually were well abused and re-bent (or cheap *** walmart chrome wheels). Aftermarket/US made wheels seem like they are more likely to be cracked without being bent due to I guess being more brittle. There isn't much liability concern, if it cracks again, weld it again. The wheel isn't going to explode and cause a wreck. As long as the customer understands there is a chance it may crack again.
CVC9216 is offline   Reply With Quote
Tig welding 3/8" cast aluminum? uberEFtuner Welding / Fabrication 8 03-16-2011 02:20 PM
fixing damaged wheels gosu08 Wheel and Tire 1 10-22-2010 10:17 AM
Possible to weld a rim? Shanlar Wheel and Tire 3 03-02-2006 11:06 PM
Anyone ever welded a rim? 2kjettaguy Welding / Fabrication 16 12-02-2005 06:31 PM
Integra Door - steel or aluminum? Tim2179 Welding / Fabrication 6 11-26-2004 05:28 PM
Tags
aluminum, california, ccracking, crack, cracked, cracking, hawaii, integra, northern, repair, rim, weld, welding, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
