stripped motor mount bolt
it appears that one of the 2 bolts that hold the mount to the block (above the water pump, below the cam gear) is stripped. Don't ask me how. I don't know.
But I would like to get your guy's thoughts. When i tighten it, it just spins. When i looked at the threads they look folded over in the hole.
do you think i can chase a tap through hole and that would be enough?
can i use a release agent on the bolt and use jb weld to reform the threads?
or should I go some type of heli-coil setup? (do they make them for anysize bolt/thread?)
thanks guys.
thanks guys.
Solbros Owns Me
heli-coil/thread insert
Best way to fix such a problem. Go to your local Fastenal/Napa, etc and buy a 10x1.25 heli-coil kit. You will drill out the hole, tap to a bigger size, and then install a metal thread insert, which is 10x1.25.
lunareg
08-30-2010 11:47 AM
