Pre polished weld "L"s.... - Honda-Tech
Old 08-19-2009, 05:02 PM   #1
antireversion's Avatar
Default Pre polished weld "L"s....
Where can I get them and what do they cost ??
antireversion is offline   Reply With Quote
Old 08-22-2009, 04:37 AM   #2
ROTARY's Avatar
Default Re: Pre polished weld "L"s....
http://www.stainlesstubular.com/poli...s_fittings.htm
not sure if they have a minimum order amount but give them a call and then let us know what they say.
ROTARY is offline   Reply With Quote
Old 08-22-2009, 09:59 AM   #3
Agtronic's Avatar
Are you looking for polished schedule pipe elbows, or polished tubing elbows?
Agtronic is offline   Reply With Quote
Old 08-22-2009, 04:14 PM   #4
ManBearPig4silly's Avatar
Weld els are pipe elbows.
I've never seen nore used them.
Lazy much?
ManBearPig4silly is offline   Reply With Quote
Old 08-22-2009, 09:23 PM   #5
Quote:
Originally Posted by ManBearPig4silly View Post
Lazy much?
Not Hardly....not as much about being lazy as being more efficient.. I have a full time (60 hr /week) job and try to knock out 2 or 3 manifolds a week for a local speed shop that sells them mail order.. I will usually spend between 4/5 hours polishing the runners and collector on each manifold...with the 10/15 hours a week I spend just polishing ,I could get more manifolds finished if pre polished L's were available......
Old 08-22-2009, 09:27 PM   #6
Quote:
Pipe elbows... 1.5 sch 10...90's, 45's and even straight sections by the foot..
Old 08-22-2009, 09:35 PM   #7
ROTARY's Avatar
IF polished elbows are available why would you want to sand and buff them your self?
Old 08-22-2009, 09:37 PM   #8
exactly...lol ^^^
Old 08-23-2009, 12:20 AM   #9
RC000E's Avatar
In for a source here. While I definitely am not willing to polish any, I did think of doing another manifold for my own car and I'd be willing to spend a little more to get a nice finished product.
Even if I could get some weld els that are worked in a tumbler to pretty them up. Wasn't AFI or someone doing that before finishing...maybe it was lovefab?
RC000E is offline   Reply With Quote
Old 08-24-2009, 10:30 AM   #10
Former Vendor
Tumbling still takes hours to polish it just eliminates the hassle of having to do it, so really he wouldn't be gaining.
How many parts are we talking here? I may be willing to do them if theres a decent quantity.
PSI2HI is offline   Reply With Quote
Old 08-24-2009, 10:38 AM   #11
plus tumbling is loud as ****.
91jdmhatchback is offline   Reply With Quote
Old 08-24-2009, 10:43 AM   #12
Former Vendor
Quote:
Yes and no. Large cutting media is loud, plastic and polishing media isn't bad.
Old 08-24-2009, 01:17 PM   #13
OG Fabricator
i just purchased a tumbler from eastwood, put in some sched 10 90's in there overnight and they barely changed at all. tried several different media types and no luck. looks like i'll be returning the tumbler unless psi2hi can share what kinda media he uses etc.
russianvr4 is offline   Reply With Quote
Old 08-24-2009, 02:00 PM   #14
hootiehoo's Avatar
you could probably make a tumbler....
hootiehoo is offline   Reply With Quote
Old 08-24-2009, 02:00 PM   #15
Former Vendor
Quote:
Idk what kind of finish your after or what machine your using but if your looking for a polished finish its a multiple process ordeal. What we use here is a ceramic cutting media w/ a cleaner soap which will basically smooth the surface and leave a bit of a shine, then to a porcelian polishing media w/ a burnishing compound if you want a polished shine look. Its a timely process and like what i said earlier if your not doing quantity your not going to save yourself any time/money.
Old 08-24-2009, 02:55 PM   #16
OG Fabricator
what soap do you use?
if you could PM me to the links of that stuff i'd appreciate it.
Old 08-24-2009, 04:30 PM   #17
We can provide #4 finish (180 grit) straight lengths of pipe as well as tees, el's and 45's...however, they will be quite pricey compared to the standard mill finish fittings and pipe we stock. If there are enough people interested I'm sure we can get the price down a bit.
If anyone is interested let me know.
AceRaceParts is offline   Reply With Quote
Old 08-24-2009, 08:51 PM   #18
RC000E's Avatar
Personally, it wasn't something I wanted to do in terms of multiple pieces, just for my own personal project. Would be a nice option to have to really make something nice.
Old 09-06-2009, 05:30 PM   #19
RickyLee53's Avatar
Quote:
If you work 60 hours, and spend 4-5 hours polishing each manifold thens surely each manifold most take you 15 hours plus making a manifold, (5 to cut, 5 to weld) thats 105 hours working in a 168 hour week.
Personally I spend less time polishing than I do cutting/welding.
What polishing method do you use?
RickyLee53 is offline   Reply With Quote
Old 09-06-2009, 06:29 PM   #20
you need a vacation.
Old 09-07-2009, 04:31 PM   #21
ALL IMPORT's Avatar
do u guys polish the pieces before u even start mocking them so u can just put them on a wheel? or do u tack everything up then takeapart then polish ? or what process exactly is the best u found.
ALL IMPORT is offline   Reply With Quote
Old 09-07-2009, 06:37 PM   #22
i polish and bevel every piece prior to tacking it up. but i spend a good amount of time holding bends in place/cutting to fit.
out with the "B" and in with the "H" garage sale kyosoeg6 For Sale 21 02-16-2012 08:21 PM
CA TRADES "92" Enkei's SOCAL! EGII Wheels 23 10-25-2010 07:45 PM
""DELETE THREAD PLEASE"" 91_LS Northern California 10 08-25-2010 08:49 PM
""". WTB. Tial 38 mm waste gate """"" turbohatch96y7 Southern California (Sales) 21 03-06-2010 01:16 PM
Tags
90s, cutting, els, honda, ls, manifold, pipes, polished, polishing, pre, series, tech, tumbler, tumbling, weld, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
