Post You Painless or re-engineered wiring
Im trying to gather information on fabricating a slimed down chassis harness ... down to the very basic essential's ..
im doing this for as much weight savings as possible
example:
no a/c
no heater
no defrost
no srs system
and other misc. things not needed
and having the engine harness totally separate
im looking for personal experience
i could'nt find very much information about this subject maybe we could get it all in here
List if your car is a street car or pure track car
example:
no a/c
no heater
no defrost
no srs system
Re: Post You Painless or re-engineered wiring
relays
fuse board
more complete
ecu,fuse panel, relays (yes i know the relays are dropping in the middle problem has been taken care of
battery box
ignition switch PTT
Kill switch
fuel pump
main fuse/circuit breaker
switch panel
fuse board
more complete
battery box
ignition switch PTT
Kill switch
fuel pump
switch panel
contact kataku2k3. he did my engine harness including motec/prologger/mw pro 12 ign. and redid my cabin harness, getting rid of all the relays and fuse boxes.
im in souther california got a phone number?
what about headlights back up lights blinders horn? radio
I make a Relay board to make this Much easier and cleaner install. i was in the same boat a while back and had to come up with something to do to keep the wire clutter down.
i sell the boards for $170 shipped 48 states.. since there made by hand. yes it comes with a diagram Very easy to use.
One Power and one ground connection
You have your Inputs(Signal) on the bottom of the board
On the top you have your outputs to control what ever
More details in my signature.
would you be more concerned for a case to cover the top or the bottom of the board? I can vaccum form a case out of ABS but getting around all the relays and terminals. Also you wouldnt be able to see the LED for active circuit.
this is all the wiring in my street/strip car other than the kill switch wiring, first picture is the cabin/chassis harness includes the headlights to the tailights. second picture is the engine/ign harness. there are four relays and one circuit breaker in the whole car. not one toggle switch on the car as well.
dont mean to thread jack but could yall also show us what each swicth controlls
foe example main power swicth
accesories
radiator
momentarie on/off swicth for starter
accesories
radiator
Here's some wiring I did. The terminal blocks are from NAPA. The switch and fuse panel is from Moroso if I remember right.
This is pretty much exactly what im looking for
can anyone do this in southern California?
how much would that cost? looks great
he said he is engine harness only to me..... idk i still need someone in so cal... all mill spec chassis harness?
