Oil Pressure Tap Cracked
I was tapping in a new fitting to run an oil pressure gauge where the stock oil pressure sensor goes when it got fractured, I pulled the motor out and sent it to a machine shop to do an aluminum weld on it. I was just wondering if it will hold up on track or if i have something to worry about. Any advise would help. THANKS.
Turtle
Turtle
Re: Oil Pressure Tap Cracked
You could have just drilled and tapped it to a bigger size, would have been easier than pulling the motor and sending it to a machine shop.
But why a machine shop to do the welding? Do you know if they do a lot of aluminum welding?
