oil drain plug stripped..... what to do?
so i just got home in my new car and went to change the oil. and the drain plug is stripped so bad that i cant even tighten it with my hand before it breaks loose.
so should i take the pan off and have someone re-tap the hole? or should i try the thread chaser? its a moroso pan so i dont really want to buy another one i would like to fix the one that is on it now. any ideas or help is appreciated
Re: oil drain plug stripped..... what to do?
Most parts stores sell an oversized drain plug,like a self tapping screw it cuts its own threads when you install it.
Doesn't cost much and more often than not will cure the problem,at least they have for me 5 or 6 times.
just drill it out and re weld a bung and your golden
YOU CAN USE A PRESSURE CLAMP tighten it very good to the bolt thats stripped and turn it until it comes off and just buy a new plug
SpeedMonkeyRacing
08-07-2003 07:07 AM
