new manifold finished, what do you think.
Old 09-28-2005, 05:59 PM
ccfab's Avatar
Default new manifold finished, what do you think.
heres my new mani i made. dangling off it is a borg warner gm-8.
goin on a solid deck b16a shooting for 400whp or more.
HERE SHE IS.. QUICKSILVIA WILL ENJOY HER.
anyone interested in one? 8)
Old 09-28-2005, 06:18 PM
hawjboi's Avatar
nice mani...looks very sexy...
Old 09-28-2005, 06:47 PM
Lamchop0000's Avatar
Default Re: (hawjboi)
it looks good.
you took a short cut on the 4-1 collector i see.
and you should back purge it too. because i see alot of slag in the inside of the manifold. which causes turbulance with the exhaust flow. and it might get burnt and chips will get into the turbo and maybe wear it out faster?
Old 09-28-2005, 06:53 PM
ccfab's Avatar
Default Re: (LamRacing)
well this is purely recreational for me. i dont backpurge cause im not made of money. yeah i used a plate for the collector where they meet in the middle.
honestly trhe only slag in there is a few little crispies from where i got too hot in one spot. other than that its clean. i got what i could with my dye grinder..
either way im sure itll work well for the 400 whp goal.
Old 09-29-2005, 04:01 AM
Jays91DXhatch's Avatar
Default Re: (ccfab)
Only other problem I see was also mentioned on HMT, you don't have enough filler, I don't think the weld is supposed to be like that, should have a slight bump at the very least.
I know you said it will hold fine blah blah blah but you should try and work on that next time
Oh, and knowing that backpurging makes a much stronger/better weld not to mention it will help exhaust gases flow as well as the possibility of not enough filler and still selling this manifold is just as bad as the ssautoshit vendors knowing their mani's suck but still sell them.
**Flame suit on**
Old 09-29-2005, 08:06 AM
ManBearPig4silly's Avatar
You need more filler and you need to purge it. Which is the exact same thing everyone said in your last thread.....
Old 09-29-2005, 08:16 AM
TIGboy's Avatar
Default Re: (I4sillypwr)
^ I agree, more filler, you dont want those to crack or break through. but VERY nice manifold, Ill be making mine soon!
Old 09-29-2005, 11:45 AM
VRD^sam's Avatar
Default Re: (Jdmboost1111)
nice work...know sell it too me..J/K
Old 09-30-2005, 07:32 AM
lkailburn's Avatar
thats a sweet mani but ya the welds look like they are cut way into the material. i think more filler for the next mani
Old 09-30-2005, 08:00 AM
legendboy's Avatar
Default Re: (lkailburn)
Your collectors need work and your undercutting your weld way too much. You shouldn't just fuse the pipes together.
Old 10-03-2005, 08:51 AM
RC000E's Avatar
Default Re: (legendboy)
Pretty nice design for the mostpart, I am just wondering about the collector in the second pic. There is a ton of gap between the four pipes coming together. Do you have a finished pic after that was filled?
Old 10-03-2005, 09:51 AM
Default Re: (RC000E)
The pic is there already. It looks like he put a square piece in there and welded around it.
Old 10-06-2005, 03:24 PM
hybridmoments's Avatar
Default Re: new manifold finished, what do you think. (ccfab)
not bad. turn down your amperage though. alot of Undercut welds and excess penetration
those look like pretty big diameter tubing. no expert but that might hurt the exhaust velocity and my create a bit more turbo lag.
Old 10-08-2005, 11:53 AM
JDM H22A's Avatar
Default Re: new manifold finished, what do you think. (hybridmoments)
since it looks like you only have a root pass i would go over it again and weave over it
Old 10-10-2005, 10:23 PM
ccfab's Avatar
Default Re: new manifold finished, what do you think. (JDM H22A)
its 1.5 icnh sced 10, just like everyone uses.... standard **** guys
cstay
08-17-2005 07:20 AM
u_tal
12-13-2004 05:52 PM
B18C1CYA
Welding / Fabrication
31
11-27-2004 07:14 PM
project dc2
03-29-2004 10:05 AM
earl
02-07-2002 09:34 PM
Quick Reply: new manifold finished, what do you think.
