Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions
Old 08-20-2004, 12:27 PM
Founding Member
Mike M's Avatar
Default Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions
Any Downsides to going with a Multiprocess machine over seperate TIG and MIG machines?
I want to get a TIG machine but also need a new MIG so I figure a Multiprocess might do the trick. I was looking at Millers XMT 304 CC/CV or Lincoln's Power MIG 300 K1694-1, Both are right under the $3000 range. If anyone has input on either of these machines or other models or brands please post.
Usage for the Tig and Mig Machines will be mostly for light fabrication, Exhaust work, random projects.
Thanks,
Mike
Old 08-20-2004, 12:37 PM
legendboy's Avatar
Default Re: Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions (Mike M)
Unless size and weight is an issue it should be fine imo
Old 08-20-2004, 04:48 PM
Vintech's Avatar
i would go with the multi machine if size isn't an issue, and I like miller better. i use both in the body shop
Old 08-23-2004, 09:19 AM
Founding Member
Mike M's Avatar
Default Re: Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions (Vintech)
Thanks for the responses, Anyone else want to weigh in?
Old 08-23-2004, 10:51 AM
dustin's Avatar
Yeah, just get a TIG.
Old 08-23-2004, 11:18 AM
mopar junkie's Avatar
Problem with the mig/tig combo's is they usually only do DC. Thats fine unless you ever plan to tig aluminum which will require AC. (Well, its not required but MUCH easier)
Old 08-23-2004, 11:38 AM
legendboy's Avatar
Default Re: (mopar junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie &raquo;</TD></TR><TR><TD CLASS="quote">Problem with the mig/tig combo's is they usually only do DC. Thats fine unless you ever plan to tig aluminum which will require AC. (Well, its not required but MUCH easier)</TD></TR></TABLE>
this isn't really true. you can get ac/dc multi process machines
Old 08-23-2004, 12:13 PM
EVIL TYPE R's Avatar
Default Re: (legendboy)
is the Millers XMT 304 CC/CV a ac/dc or just a dc? (just curious)
Old 08-26-2004, 02:05 PM
Founding Member
Mike M's Avatar
Default Re: Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, just get a TIG.</TD></TR></TABLE>
And in the end I think thats what I am doing
Thanks for the suggestions, info, and helping me decide on the Miller Dynasty 200DX
Old 08-26-2004, 02:13 PM
Founding Member
Mike M's Avatar
http://millerwelds.com/products/tig/dynasty_200/
On the Right..
2s10w4u
06-11-2005 11:02 PM
SoSlo
Welding / Fabrication
03-28-2005 09:58 PM
DeLiRiOu5
Honda Motorcycles
03-03-2005 07:25 PM
RACEPAK
12
02-07-2005 12:39 AM
spoon23_JDizM AkA SpOoN20
11-20-2003 08:21 PM
Quick Reply: Need Input - Multiprocess Welder or Seperate TIG & MIG - Suggestions
