Joining Aluminum Tubing - Honda-Tech
Old 05-27-2009, 08:54 AM   #1
B18C_EJ8's Avatar
Default Joining Aluminum Tubing
I posed this question late last night in GDD, because I forgot all about this section. Copy & pasted below are my posts:
I have two 5 foot sections of aluminum tubing that I need to connect end-to-end in the strongest manner possible.
Dimensions of the tube is 1.75" OD, 1.575 ID.
Which would be stronger?
Connect the tubing with a 12" section of piping, on the outside, bolted/nutted through both "layers" on both sides of the joint?
Or, connect the two pieces with a section of piping inside of the two sections, bolted/nutted through, on both sides of the joint?
<questions were asked, and my answers follow:
It will be loaded on one end, attached at the other, 10 feet away, parallel to the ground.
The two ends will be butted up against each other as close as possible.
Wall thickness of the 12" section is TBD, but probably equal to or greater than the .089" wall thickness of the tubing being joined.
The general consensus was to use larger tubing around the outside of the piping to be joined. What do you experts think?
Also, how much trouble would it be to make this whole assembly screw together with threads? More trouble than it's worth, I suppose...
B18C_EJ8 is offline   Reply With Quote
Old 05-27-2009, 08:55 AM   #2
B18C_EJ8's Avatar
Default Re: Joining Aluminum Tubing
Forgot to add that I can't just weld the two pieces together. I need to assemble & break it down in the field for transport, since 10' of pipe won't fit in my 2 door Accord.
Old 05-27-2009, 11:25 AM   #3
k24em2's Avatar
What is it going to be loaded with?
k24em2 is offline   Reply With Quote
Old 05-27-2009, 11:31 AM   #4
B18C_EJ8's Avatar
Stuff.
Miscellaneous equipment not exceeding 10 pounds.
Old 05-27-2009, 12:20 PM   #5
Stachi's Avatar
Why not weld a bolt into one and a nut into another on?
Marc
Stachi is offline   Reply With Quote
Old 05-27-2009, 12:28 PM   #6
B18C_EJ8's Avatar
^^^ Like end to end and screw them together?
Definitely a good idea, but I'm also trying to do this for free.
I don't weld, nor do any of my friends, so I'd have to pay to have it done.
Old 05-27-2009, 01:14 PM   #7
k24em2's Avatar
Just slip the 12" piece over both and put a bolt through each end
Old 05-27-2009, 02:43 PM   #8
Bailhatch's Avatar
camera mount?
I say use a sleeve over the outside also.
Bailhatch is offline   Reply With Quote
Old 06-01-2009, 02:43 AM   #9
just 10LBS ?
bolt and a nut combo, also drill extra holes in the smaller one so it's adjustable, if you still don't feel safe ad another bolt. best way to do it is to weld them together, but you're on a budget/no welder so best way you're getting it
i drive a honda is offline   Reply With Quote
How To: Brake Line Tuck Guidelines.. Weak!EG Suspension & Brakes 1122 10-23-2015 08:48 AM
[FAQ] Civic EG/EH 92-95 JDM Headlight Washer / Rear Wiper / Trunk Light Install DIY deschlong Honda Civic / Del Sol (1992 - 2000) 56 04-01-2015 08:02 AM
DC2 brake ducts, solid design not all zip ties and duct tape court76wi Road Racing / Autocross & Time Attack 54 07-03-2012 12:27 PM
Structural Analysis of Aluminum Tubing... B18C_EJ8 General Discussion and Debate 32 05-27-2009 09:57 PM
Homemade 3" Exhaust Resonator... The Mick Forced Induction 6 08-05-2002 08:36 PM
Tags
aluminum, clamp, copy, ends, fit, joining, screws, threads, tube, tubes, tubing, ways, weld, weldable, wiggins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
