JB weld on valve cover??
Might be a ridiculous question. Can you use JB weld on the valve cover? I want to put 2 ports in it. Drill 2 holes, jb weld the 2 ports into the valve cover. It's for a breather tank on a turbo setup. Rather then welding 2 ports on it professionally. Thanks, hope that makes sense.
Re: (HMTforlife)
like HMTforlife said, just prep it well.
mine has been jb'd for 2years and have not cracked loose/leaked or had any problems with it.
cheap but it works perfect for me.
Re: (H22_TURBO)
That's what I was thinking. Definitely have to prep it well, easy part. What do you guys suggest using to make the ports, just your typical electric drill?
Re: (VTECth1s)
then take it to a buddies house and diy it with a tig. i just don't understand boogering up your valve cover and potentially have issues to say "yup. did it myself".
Modified by under_boost at 10:02 AM 7/27/2008
whatever, u can wirewheel the JB weld off easy if u need to. do it up!
it wont leak. prep well, mix evenly, apply evenly.
use atleast 1/2inch hose
post up pics on HMT when ur done
Re: (under_boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by under_boost »</TD></TR><TR><TD CLASS="quote">why not just get it done right?</TD></TR></TABLE>
x2
x2
Re: (under_boost)
x2
x2
* B A N N E D *
Re: (under_boost)
This is what I ask all my friend (the few) who rig ish up.
Re: JB weld on valve cover?? (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E »</TD></TR><TR><TD CLASS="quote">They make A/N fittings that are "compression" fittings. They use a nylon seal on the backside, so it's a no weld/no leak deal.</TD></TR></TABLE>
theyre called bulkhead fittings. you can get them and everything else on summit.
i did my valve cover with bulkhead AN fittings and works just as good as welding it.
