JB weld didnt work...tranny
Old 10-02-2005, 10:56 AM
P@@RB@Y's Avatar
Default JB weld didnt work...tranny
I cleaned the area around the crack on my tranny and let it dry.I let the JB weld dry for like 3-4 days and when I screwed the bolt in it cracked the JB weld.Its holding the fluid better than it was but its still leaking slowly.
What kind of welding do I need to do on a aluminum Honda tranny?
Old 10-02-2005, 11:07 AM
Diego Dangers.'s Avatar
according to a trans shop they said, that it has to be fully taken apart and cleaned and then TIG welded.
Old 10-02-2005, 11:57 AM
P@@RB@Y's Avatar
Default Re: (di3go)
But it that coming from someone just wanting to make alot of money or the actual process?
Old 10-02-2005, 12:36 PM
Flashmn's Avatar
Default Re: JB weld didnt work...tranny (P@@RB@Y)
No ****, like I've said many times before JB weld is not welding, it doesnt fuse metal and it doesnt hold cracks from growing. TIG welding is the only way to do it.
Old 10-02-2005, 12:59 PM
tony1's Avatar
Default Re: JB weld didnt work...tranny (Flashmn)
Yeah, you have to tig weld it and it has to be clean and free of oil. Aluminum won't weld if there's oil on it. You have a pic of it?
Old 10-02-2005, 01:11 PM
Default Re: (P@@RB@Y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y &raquo;</TD></TR><TR><TD CLASS="quote">But it that coming from someone just wanting to make alot of money or the actual process?</TD></TR></TABLE>
the actual process.
Old 10-08-2005, 10:21 PM
90civichb's Avatar
Default Re: (di3go)
I had a crack in my tranny from someone removing the large cap at the end that comes off with a ratchet.. It cracked around the thread and back in to the tranny..
I was told to try quicksteel on it.. I followed the directions, sanded it down, cleaned it really well, and continued with how to properly apply the stuff.. I know it isn't welding, but it has held up great to this day.. No more cracking, and no more leaking at all..
Old 10-09-2005, 12:50 AM
ExploitedRacing-HR's Avatar
Replace the part of the housing that is cracked.
Old 10-09-2005, 08:10 AM
P@@RB@Y's Avatar
Default Re: (ExploitedRacing)
Yeah I probaly have to do just that.Replace that housing part.I think the problem is that the crack is right where the head of the bolt tightens down at.so it tears the JB weld off when tighten it.
Old 10-09-2005, 10:07 AM
ccivic's Avatar
Default Re: (90civichb)
I did the same as 90civichb except with JBWeld (the standard stuff).. works great. You just have to make sure that you really glob it on there. For JBWeld For being ghetto
Also.. keep the screw in, and just glob JBWeld on it.. worked for me.
Old 10-09-2005, 02:59 PM
Colin's Avatar
Not sure where your crack is, but I was able to fix my trans w/ jb weld. The tranny came out of a wrecked car, the front mount bolt tore out of the trans.
I first took the tranny to a local shop to see how much it would cost to fix. He said that these transmissions are made of pretty low quality aluminum, and that fixing them was difficult. After mandatory hot-tanking and all the labor it was going to be very expensive to have him repair it. I forget the exact price, but it was more than I was willing to pay.
I ground away the original threads, machined an aluminum insert and tapped it w/ the appropriate sized threads. Then used jb weld to hold the insert in place. The pics pretty much speak for themselves, but feel free to let me know if you have any questions.
On to the pics:
Ground way the original threads
Threaded insert, note how it has been flattened on a couple sides.
Insert in place
Mount bolted to trans in order to insure correct location of the new insert
Modelling clay was used to create a "dam" to hold the jb weld in place while it set
Mount and clay removed
After excess JB weld was removed
A couple last notes:
1) I've been daily driving the car w/ this repair for around 3yrs now including one track day at Streets of Willow, and its holding just fine. Although I doubt that this mount really takes on any serious forces compared to many of the other bolts that hold the tranny in place.
2) I will still be buying another tranny case when this trans gets rebuilt. The JB weld seems to be holding up amazingly, but still, I'd like to have it fixed the right way.
Old 10-09-2005, 04:28 PM
P@@RB@Y's Avatar
Default Re: JB weld didnt work...tranny (Colin)
Damn good work.
Its been holding up ok for a week now.ive had to add a little fluid to it.Im thinking of redoing it and using the quicksteel or somehow making the JB thicker and seeing if thats works.
Old 10-09-2005, 11:29 PM
VRD^sam's Avatar
looks good
Old 10-10-2005, 12:02 AM
red92si's Avatar
Thats probably the best JBWeld job I have ever seen.
Kudos.
Old 10-10-2005, 01:59 AM
O3DigitalBath's Avatar
for real...that came out nice
Old 10-10-2005, 07:18 AM
RACEPAK's Avatar
Default Re: (O3DigitalBath)
wow nice work yo!
Old 10-10-2005, 07:01 PM
morepoop4u's Avatar
Ghetto fab haha Why didn't you just weld the piece you made in place.
Old 10-10-2005, 07:23 PM
mike93eh
Guest
Posts: n/a
quicksteel.
it work wonders on my crack radiator on the lude. (the quicksteel for plastics)
Old 10-10-2005, 08:28 PM
LargeCaucus's Avatar
id put jb weld on a trans before it worked ok
Old 10-10-2005, 09:36 PM
i HAS questions ?
.dave's Avatar
Default Re: JB weld didnt work...tranny (LargeCaucus)
I think if Engloid used JB Weld it'd come out like that.
Old 10-11-2005, 01:36 PM
Colin's Avatar
Default Re: JB weld didnt work...tranny (morepoop4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morepoop4u &raquo;</TD></TR><TR><TD CLASS="quote">Ghetto fab haha Why didn't you just weld the piece you made in place.</TD></TR></TABLE>
Well, at the time I didn't have a welder, and I wasn't about to pay the local shop to do it (since he was gonna charge a lot, plus a mandatory hot-tank fee).
thanks for all the compliments guys!
Old 10-11-2005, 03:07 PM
Tony the Tiger's Avatar
JB weld works great if there is a lot of surface area for adhesion. Colin's work is a good example of how it should be used
chinoty
Welding / Fabrication
02-08-2006 11:07 AM
Jet Black
09-21-2005 05:27 AM
P@@RB@Y
09-13-2005 08:17 PM
Pete_SI
18
07-28-2005 05:47 AM
gliaw
01-22-2004 07:25 PM
Quick Reply: JB weld didnt work...tranny
