hairline crack n oil pan.
Old 04-11-2006, 10:56 PM
Cheeech's Avatar
Default hairline crack n oil pan.
could i just weld the crack so it wont leak anymore or MUST i buy a new oil pan?(which i dont have any more for)
Old 04-12-2006, 12:37 AM
Lamchop0000's Avatar
Default Re: hairline crack n oil pan. (CheechJDM)
yeah, you can repair it.
just dont weld it with it on the engine
Old 04-12-2006, 12:49 AM
AspectIndustries's Avatar
Default Re: hairline crack n oil pan. (Lam.N)
Yea, remove the pan and clean it. Grind off the material around crack, then weld tha sucker up! Should be easy to do. Just taking them nuts off the pan sucks ***, especially you dont have access to a lift.
Old 04-12-2006, 04:13 PM
Cheeech's Avatar
thanks for the info, but seems like a pain because i have to remove the headers as well, but worth a try.
Old 04-12-2006, 05:54 PM
blueoval557's Avatar
Default Re: (CheechJDM)
Whatever you do, dont just weld it up. Take it off the car, clean it up real well, and then find both ends of the crack. Once youve found the ends...go about 1/4" farther out, and drill a small hole (1/8" or so). Once you have both holes drilled about a 1/4" away from the ends of the crack, you can then weld it up, and just fill the holes with filler wire.
This helps to keep the pan from cracking again. If the crack jus stops as a crack, it will continue to crack...but if it stops with a rounded shape(circle from the hole you drilled), it will eliminate it from cracking. Also...you need to go 1/4" past the crack on each side, because just because you cant see the crack, doesnt mean it stops. A crack usually starts on the inside of the metal, so it may not be cracked all the way through yet, (or it is and you cant see it because its so minute), so by going beyond what you can see, you are sure to get the entire crack.
Shouldnt be a hard job at all...and quit bitchin about taking the header/exhaust off! haha. If you had to buy a new pan, youd be doing the same thing. Good luck man.
Kyle
Old 04-14-2006, 08:04 PM
RuskeR's Avatar
Default Re: (blueoval557)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueoval557 &raquo;</TD></TR><TR><TD CLASS="quote">
Kyle</TD></TR></TABLE>
good point and worth a try
Old 04-15-2006, 12:39 AM
Cheeech's Avatar
Default Re: (RuskeR)
yea i know, im going to do it this weekend hopefully everything goes good
JdmMidWest
02-20-2012 05:20 PM
94eg!
02-07-2011 08:35 PM
blackeg
06-06-2009 11:06 PM
columbushatch
Welding / Fabrication
10
12-05-2008 04:40 PM
iukaman
01-12-2008 06:39 PM
Quick Reply: hairline crack n oil pan.
