FSW friction stir welding. AMAZING!
Old 11-10-2010, 03:00 PM
hondalover91crx's Avatar
Default FSW friction stir welding. AMAZING!
http://www.youtube.com/watch?v=jCe8-QYKZf4
EDIT: the music is the best part.
Old 11-10-2010, 06:18 PM
Not to be confused with "THE MAN"
THE GUY's Avatar
Default Re: FSW friction stir welding. AMAZING!
quite interesting.
Old 11-12-2010, 11:43 PM
jzz30's Avatar
if you ever get under an 05+(?) sti you will see some friction stir welded suspension arms, where the sway bar link braket is welded on using this method. its very clean looking
Old 11-14-2010, 04:44 AM
jere's Avatar
I am confused, so the metal is not being liquefied?
Old 11-15-2010, 07:30 AM
hootiehoo's Avatar
it is, but the heat is from the friction, no arc.
Old 11-15-2010, 01:33 PM
from the looks of it, its heating it up with friction and stirring the 2 halfs into eachother, i question if its truely liquified or only heated to a maluable mush and sort of buffed flat by the large puck above it. either way its super cool.
Old 11-15-2010, 02:50 PM
TunerN00b's Avatar
The latter.
http://en.wikipedia.org/wiki/Friction_stir_welding
This heat, along with the heat generated by the mechanical mixing process and the adiabatic heat within the material, cause the stirred materials to soften without reaching the melting point (hence cited a solid-state process), allowing the traversing of the tool along the weld line in a plasticised tubular shaft of metal.
josephcmiller2
Suspension & Brakes
04-27-2011 04:53 PM
AFAccord
11-29-2005 07:36 PM
Spikes11
02-10-2004 09:27 AM
b18crx
01-02-2004 08:28 AM
DMCsteve
07-23-2002 07:22 AM
Quick Reply: FSW friction stir welding. AMAZING!
