looking for opinions on this block!
Old 08-04-2008, 07:23 PM
mr.coupe's Avatar
Default looking for opinions on this block!
decided to ditch my k24 project and picked up a k20a2 for a awesome deal....only problem...
came out of a wrecked rsx....a/c compressor was hit hard...and thats the damage....haven't started taken it apart yet just got the motor tonight..getting to work on it tomorrow. I know of some very good alluminum welders local so just looking for some opinions before I take it to them
Old 08-04-2008, 08:36 PM
TigWiz's Avatar
Default Re: looking for opinions on this block! (mr.coupe)
I repaired a VQ block that had a very similar problem, and it is going to take a lot of work. Deep grooves need to be made, and holes will have to be partially filled, drilled, and retapped. It can be done though, Good Luck!
PS: If there is no oil presure behind any of the holes then you'r fine. The VQ cracked on an Oil Presure Sensor port, and was a ***** to make it seal correctly.
TigWiz
Old 08-04-2008, 08:43 PM
Shooting Star
vtecspeed1320's Avatar
You can always get a new timing side cover, but where the girdle is hit and rides up a little might be of some concern, your not using ac in your car anyways are you?
That will always be an oil lead if its not fixed correctly.
Old 08-05-2008, 01:08 AM
JDM_DC4_Fanatic's Avatar
Default Re: (vtecspeed1320)
if you still have the K24 motor, I would use the block from that. I am building a K24A4 with K20A2 head for my next CB. More torque and good top end
Good luck on the welding though.
Old 08-05-2008, 11:58 AM
mr.coupe's Avatar
Default Re: (JDM_DC4_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">if you still have the K24 motor, I would use the block from that. I am building a K24A4 with K20A2 head for my next CB. More torque and good top end
Good luck on the welding though.</TD></TR></TABLE>
well thats what I was doing but decided to ditch the k24/k20 project and go with this swap....picked this complete swap up for $2600 so I'm not complaining.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">You can always get a new timing side cover, but where the girdle is hit and rides up a little might be of some concern, your not using ac in your car anyways are you?
That will always be an oil lead if its not fixed correctly. </TD></TR></TABLE>
New timing chain cover is about to be ordered...just need to start ripping this apart and see whats up with the lower portion of that block. Yeah I'm not using a/c so I don't even need that hole for the 14mm...so I'm just gonna have them weld it up just to be safe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TigWiz &raquo;</TD></TR><TR><TD CLASS="quote">I repaired a VQ block that had a very similar problem, and it is going to take a lot of work. Deep grooves need to be made, and holes will have to be partially filled, drilled, and retapped. It can be done though, Good Luck!
TigWiz</TD></TR></TABLE>
yeah it doesn't seem like it will be to bad..I'll post more pics as I tear this down more.
bigkvn77
03-18-2009 08:57 AM
TypeSLO
09-11-2006 12:40 PM
em1 Ziggy
05-12-2006 11:08 PM
IH82LOSE
10-03-2003 01:54 PM
1genCL
06-02-2003 04:42 AM
Quick Reply: looking for opinions on this block!
