Fabbing an exhaust cutout w/ a throttle body - Honda-Tech
Old 08-26-2005, 02:15 PM   #1
B18Flip's Avatar
Default Fabbing an exhaust cutout w/ a throttle body
Just wondering if anyone has tried it out. i was thinking of using a 3" domestic tb instead of those electric ones that always break. Do you guys think it'll hold the exhaust pressure ok when it's closed?
B18Flip is offline   Reply With Quote
Old 08-26-2005, 05:06 PM   #2
Flashmn's Avatar
Default Re: Fabbing an exhaust cutout w/ a throttle body (B18Flip)
Well they hold boost pressure on turbocharged cars without much problems and thats way more than your exhaust pressure is gonna be.
Flashmn is offline   Reply With Quote
Old 08-26-2005, 05:26 PM   #3
cstay's Avatar
Default Re: Fabbing an exhaust cutout w/ a throttle body (Flashmn)
but your intake isint over 1000 degrees
cstay is offline   Reply With Quote
Old 08-26-2005, 07:48 PM   #4
EPIC TUNING
E-Rok's Avatar
Default Re: Fabbing an exhaust cutout w/ a throttle body (cstay)
Quote:
ding ding ding
U need steel y0
E-Rok is offline   Reply With Quote
Old 08-26-2005, 08:34 PM   #5
B18Flip's Avatar
Quote:
yeah i guess so
true, but i'll try to put it down stream more so it's not as hot.....full-race geoff uses an aluminum catback so i think it should hold up.
Old 08-26-2005, 11:27 PM   #6
h kid's Avatar
acually it holds up the heat perfectly well. i tried it with a Nissan 240 tb on my hatch and put it between the block and radiator, it held the exhaust in when closed,no leaks and i had it in there for about 5 months with no problems i say go for it
h kid is offline   Reply With Quote
Old 08-27-2005, 09:13 AM   #7
Brrraaaap!
Blaze45's Avatar
Default Re: Fabbing an exhaust cutout w/ a throttle body (h kid)
The DMH electric ones have a 4 year warrenty on the entire unit. It'd have to be a pretty big TB to flow what you'd like anyways.
Blaze
Blaze45 is offline   Reply With Quote
Old 08-27-2005, 09:21 AM   #8
blueoval557's Avatar
Default Re: Fabbing an exhaust cutout w/ a throttle body (Blaze45)
Lol at aluminum not holding heat....how did anyone come to that conclusion?? HAHAIt will hold up fine...do it...I want to see it! LOL
Kyle
blueoval557 is offline   Reply With Quote
Old 08-27-2005, 02:57 PM   #9
Full-Race Javier's Avatar
some one over on sr20forums runs a tb cutout (NA application though)...bunch of pics and a vid in this thread
http://www.sr20forum.com/showt...utout
Full-Race Javier is offline   Reply With Quote
Old 08-27-2005, 07:05 PM   #10
Default Re: (Full-Race Javier)
its doable,
ccfab is offline   Reply With Quote
Old 08-27-2005, 07:16 PM   #11
B18Flip's Avatar
ahh perfect! that's what i need
Old 08-27-2005, 07:48 PM   #12
shortyz21's Avatar
Default Re: (B18Flip)
yeah then just use a string in the cab to pull it
hahahah this is HMT all the way. keep us updated!
shortyz21 is offline   Reply With Quote
Old 08-27-2005, 08:18 PM   #13
buckfittyone's Avatar
Default Re: (shortyz21)
i wanted to do one with this d16z tb i have but it has several holes in it that would leak the exhaust fumes around the throttle plate,anybody know of any cars with oem tbs with no extra holes to leak exhaust gas past the throttle plate?
buckfittyone is offline   Reply With Quote
Old 08-27-2005, 08:22 PM   #14
snowseeker's Avatar
Default Re: (buckfittyone)
I have one on my car. I used a dsm throttle body.
snowseeker is offline   Reply With Quote
Old 08-28-2005, 12:12 AM   #15
B18Flip's Avatar
Default Re: (snowseeker)
awesome, i'll def trying this out Do you guys know of any 3" TB's that don't have the holes like people were saying?? If not i'll just zap the holes w/ the mig welder lol
Old 08-28-2005, 10:29 AM   #16
dfoxengr's Avatar
Quote:
yeah zap that Al. do you have a spool gun and pure Ar?
dfoxengr is offline   Reply With Quote
Old 08-28-2005, 01:03 PM   #17
turbotommy's Avatar
Default Re: (dfoxengr)
but boost isnt realized when the tb is closed.
there is no doubt a al tb will hold up. BUT not all the operating parts inside of tb's are al. you have spacers, gaskets, springs, etc. things that a prone to heat warping and cracking with the rapid heat up and cool down process w/ boosted cars AND the rapid heat up and cool down of al. then again the tb cutout will be under the car where airflow will be high..as far as placing the tb downstream more. you dont wanna lose the effect the tb gives. you want it placed where the exhuast heat begins to "cool" so that your down pipe and its "dump" will be efficient.
ps. i have never ever EVER talked to someone with an e-cutout that hasnt had problems. be it electric or manual.
turbotommy is offline   Reply With Quote
Old 08-28-2005, 01:20 PM   #18
k24em2's Avatar
Default Re: (turbotommy)
Quote:
When you let off the gas from a full throttle run there is.
k24em2 is offline   Reply With Quote
Old 08-28-2005, 01:40 PM   #19
B18Flip's Avatar
Default Re: (k24em2)
eh i'm going to try it out, it seems that it has worked out for the people who have tried it
Old 08-28-2005, 02:39 PM   #20
Flashmn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by turbotommy
When you let off the gas from a full throttle run there is.</TD></TR></TABLE>
Right....and on cars without dump/blow off valves, pressure has to stall the turbine, go the other way and that takes fairly long to happen... (oh and I know its not good, people still do it)
Old 08-28-2005, 03:48 PM   #21
snowseeker's Avatar
Yes the plastic spacers and washers and seals can melt. I pulled mine apart and removed all of the plastic. Sorry people, forgot to mention that.
Old 08-28-2005, 06:50 PM   #22
B18Flip's Avatar
Quote:
yup i'll def do that....btw how big is the dsm tb??
Old 08-29-2005, 11:11 AM   #23
TeamNextGenChris's Avatar
i've been running a Quicktime cutout for about a year and a half with no problems yet.also installed a couple on people's cars with no problems.
Chris
TeamNextGenChris is offline   Reply With Quote
Old 08-29-2005, 07:37 PM   #24
rhd
joey davis has been talking about doing this forever...he's had the t/b for a long time....i've always been interested in doing it...if he can get it to work alright
rhd is offline   Reply With Quote
Old 08-29-2005, 09:00 PM   #25
butterfly type valves assemblies have been used in the turbo industry for a while with out a problem. these arent AL though. only thing is that the valves im referring too are used to impede flow and or raise exh mani pressure not the other way around....and they are $$$
What exhaust is this? DAMN its SiJ Honda Civic (2006 - 2015) 35 10-06-2009 03:00 PM
FS: Greddy EVO2 for EG Hatch 92-95 Civic Exhaust Catback Evo 2 Denton kicked25th Texas -OK -LA (Sales) 4 10-05-2008 06:10 PM
wut u think about this exhaust??? gsrpedro Honda Civic / Del Sol (1992 - 2000) 5 08-04-2007 12:13 AM
awesome F1 exhaust. Mr.Nakata Acura RSX DC5 & Honda Civic EP3 6 08-03-2007 12:40 PM
88-91 CRX Greddy SP2 Catback Exhaust Pics Wanted... CaliforniaHighwayPatrol Honda CRX / EF Civic (1988 - 1991) 17 08-20-2005 06:49 PM
Tags
body, civic, crx, cut, cutout, dump, exhaust, honda, kawasaki, made, ninja, open, tech, throttle, throttlebody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
