Eastwood 200 ac/dc tig welder reviews
#26
Re: Eastwood 200 ac/dc tig welder reviews
I sure would like to get a tig machine at some point. My mig gets the job done but the welds are just ugly compared to tig welds.
Out of curiosity, if I am able to lay a decent bead with a mig machine would it take very long to pick up tig?
#27
think of it this way remember you were in school and they made you play the flute, thats like mig. now think of something like the piano. thats tig welding, everyone has their own style and continues to perfect it
#28
Tig welding is NOTHING like mig welding. Totally different concept and process for performing the welding. Different gases and tungsten rods, different filler rods, pre and post gas flow and flow rates then technique's and CLEANING CLEANING CLEANING Did I mention Cleaning
#29
thats a pretty solid machine. I like that air cooled torch too vs the water cooled. Anything under 200 amps water cool just doesn't make any sense to me. Just more fatigue on my hands. those air cooled torches are the ****, they are so light and flexible
#31
That's what I had heard. So let me ask you guys for aluminum, are you typically running a grey or purple tungsten?
#32
how many amps it can handle I guess. I on my dynasty I can get away with smaller size because I can set the alum settings so the tungsten don't get blown out.
try running a 1/16 tungsten at 400 amps and you will see it cant handle that much heat. it will start to blow out
#35
The size is the diameter of the tungsten electrode. The thicker the electrode, the more current it can handle. A given electrode will be able to handle more amps in DC than in AC due to DC inputing less heat in the electrode per amp. If you are welding in AC, the more cleaning you have your balance set to, the more heat that is being generated in the electrode. If you crank your balance to max cleaning, you can actually watch the tip of the tungsten melt into a ball.
#36
I'm about to purchase this Eastwood machine... Thanks to this thread for helping me decide.
I've searched here and all over the web and couldn't find a real definitive answer...the question I have is, what is the difference between sourcing a 110V or 220V? From the info I gathered, it is basically this: Higher Voltage = less Amp draw and vice versa. Can anybody elaborate on this? Thank you for your time.... sorry for a beginner question.
#37
I have had mine for about 3 years now and have only done 110V welding. it has yet to fail to weld what I have needed done. my new shop I am currently wiring to have a 220V source, so I'm eager to see what differences there are
#38
yes, please post your review afterwards. In my case, I can go either way. My laundry room is next to my garage and I can easily run a 220 receptacle. But if the difference is not noticeable, then I'll just stick to 110. Thank you for the reply....
#39
You won't be able to go as high on 110v as you can on 220v. My AHP AlphaTIG 200X will only go up to ~140 amps on 110v, but will go all the way to 200 amps on 220v.
#41
90% of the welding I will do can be done easily with 110v power. The extra punch would be nice for some of the thicker aluminum I plan on welding though.
#45
#46
#48
Here's an intake manifold I've been welding up using my Eastwood Tig. I don't weld aluminum a lot but other than being able to play with ac frequency/pulse I've found the machine to mainly be limited by me the user. The better I've gotten with my prep work and fit up the better my projects have turned out.
