diy filled b series block, with writeup, comments welcome
Old 03-19-2009, 03:17 PM
  #626
New User
turbob20hatch's Avatar
Default Re: diy filled b series block, with writeup, comments welcome
seems like this thread is dead but with all due respect this does work... drill your main holes for the headgasket bigger than holes in the gasket its self and then just drill smaller holes about .5 inches apart like on abes or darton sleeves in pics. i filled mine with devcon up to the water pump hole then after that dried i filled with salt to a little above the water pump hole then filled to about .5 inch to the top with the devcon since the top of the sleeve is where all the heat transfer takes place. theres a dyno pull on you tube tuned by phearable.net making 536 with this same set up as i am making 478 @ 21psi and have been for over 1.5 years now...daily driven..
Old 03-19-2009, 04:46 PM
  #627
TheCheeseWedge's Avatar
Originally Posted by mrbsponge
i have actually seen some V8 guys fill thier blocks completely with concrete, but these were on mud racers that only drive for about 10 seconds tho
ive heard that too, has anyone done this with a honda? lol
Old 03-19-2009, 07:48 PM
  #628
srmofo's Avatar
who dug this damn thread out of the trash?
Old 05-09-2009, 12:03 AM
  #629
malik289's Avatar
anyone know whats the largest bore i can go using this method on a b18a1 block ?
Old 05-09-2009, 02:43 PM
  #630
philafelman's Avatar
after killing off an hour of my life (dont feel bad, i wasnt doing anything anyways), i can sum this thread up in 4 posts...."i filled my block, it should work"..."i dont think it will work any better than a block guard, but it might"...."i cracked all my sleeves under 20+lbs of boost"...."so will it work, maybe, maybe not"...there, i saved everyone a ton of reading without all the weird drama and break up stories.
Old 05-12-2009, 08:50 AM
  #631
hondaZvic's Avatar
i got through 3 pages, thinking no-way.. this cant be for real.. figured i'd jump to the last and see what happened. thanks for the re-cap.
Old 12-23-2009, 07:05 AM
  #632
maipaul_e's Avatar
I had and idea and want to know if anyone has tried it. I was thinking instead of making a block guard with the Devcon could you make block posts like the ones Edyne sells?
I like to block posts here:
http://www.theoldone.com/components/..._post_kits.htm
but I don't like drilling and taping the block. I was thinking just fill the salt lower build it up on the sides maybe use wax paper or something to get a "U" to fill in with Devcon.
I have searched but have not found any info.
Old 12-23-2009, 11:30 AM
  #633
welfarepc's Avatar
you cant find any info, so you bumped an old thread full of fail. good job.
Old 12-23-2009, 08:08 PM
  #634
srmofo's Avatar
Why did someone dig this outts the garbage again? see post 628
Old 12-23-2009, 09:30 PM
  #635
madblkscientist's Avatar
Originally Posted by onemanlan
I never understood why doubters would swarm to this topic. They're the worst of all people in my opinion. They have no definate stance, or their stance is for something they feel comfortable with and they lash out at any susggested change to their complacent system. That is until somebody blatantly prove's to them that a new system is better, or worthy, or their use. Then the cycle continues.
I am not saying that having doubt is a bad thing, its a cautionary measure we all have, but don't live in it or perscribe to it.
Anywho I'll be Devcon'ing my b18 too soon after I get my machine work done. I'm only shooting for 330HP-ish, but that will probably be the last engine mod I commit to for a while. I'm pretty sure that it will hold.
thats democracy for ya lol,thats why obama is getting raped by the republicans its a miracle america gotten this far in 400 yrs
Old 12-23-2009, 09:54 PM
  #636
Default Re: (musubi is good)
Originally Posted by ccfab
grainger sells devcon. so does allied.
i would use the devcon.
ahhhhhhhhhhhh ur right and i work in construction at fountain bleu they got pallets of this **** imma ask the gc if i can get 1 lol freeee bbbbbbb
Old 12-24-2009, 02:07 AM
  #637
Vagitarian's Avatar
Josh is a fukin toolbag and has failed miserably at every build hes attempted
Old 01-04-2015, 05:39 PM
  #638
ekhatch1227's Avatar
Bump this for a hilarious trial of block filling only 9 years old or so.
Old 02-22-2016, 07:25 PM
  #639
TravisBiggie's Avatar
Yes, I am bumping this from the dead. Just did this today. I was not able to level it perfectly, but its alright, I will be taking a file to the high points once its cured, and I will be drilling some holes like the op did, but I will do a few more for extra cooling. Worked out pretty well.
Old 02-23-2016, 05:21 PM
  #640
Pro-SeriesFab's Avatar
Good times . . . I wonder if devcon can be machined . . .
Old 02-24-2016, 04:41 PM
  #641
sure, why not. I'm just going to use a file to hit the high spots anyways.
Old 02-27-2016, 08:02 AM
  #642
popwars123's Avatar
I did one last month using the devcon f2. I must say that flushing all the salt was a pita! I wanted to make sure every little bit got out. However for prep I used a 1/2" "bottle brush" on the end of a drill and it worked great. The end result looks really good and really promising. The sleeves are now the least of my worries on this fun for cheap build... the cast nippon turbo pistons at over 500 hp are what I'm worried about!
Old 08-03-2017, 06:53 AM
  #643
antoni's Avatar
Default Re: (StatGSR)
Hello
Its now 11 years later.... How long did it last and how did is brake? What would be you advice i want to fill my block to
Old 10-21-2017, 05:47 AM
  #644
No Jodas
ShinsenTuner's Avatar
Are you getting the cylinders honed/bored next? My concern would be that the Devcon expands when cured which then distorts the walls.
Old 10-23-2017, 04:10 PM
  #645
Anytime you use a block filler, be it the Moroso "name brand" stuff or devcon or even concrete, it will distort the bore slightly as you've stated.
You should always get the block bored/honed afterwards. I know in the moroso concrete kit it says that in the directions but obviously here we've used some stuff that doesn't have any directions since it can theoretically be for whatever.
Old 06-16-2018, 06:53 AM
  #646
yaaj1320's Avatar
BUMP...LOL
I have a DIY filled block..
700WHP and cylinder #2 has coolant in it..Head will be taken apart tomorrow.
Cracked sleeves or maybe just blown head gasket.
I hope its a head gasket so I can see how far much further I'm able to take it.
I'll take pics and post it soon..!
EJ2GOON
Engine Management and Tuning
05-01-2012 05:01 AM
TypeR_#_039
11-25-2011 06:15 PM
sinister357
08-23-2007 05:30 PM
Quick Reply: diy filled b series block, with writeup, comments welcome
