b-series trany adaptors for RWD trany.
does anybody know of any adaptors ever made to put a honda motor to a RWD transmition? i want to put a b16 in a datsun 510 but theres no way im going to put FWD in it, ever!, so yeah if anybody has ever heard of a RWD transmition adaptor to adapt a nissan,,,,,etc RWD trany to a honda motor, LET ME KNOW.
Re: b-series trany adaptors for RWD trany. (solpower)
I dont think that anyone has came up with that specific of a combination or anything of that sort but you can always be the first. Fit the shafts and have a plate made up at a machine shop. Take the measurments and what not and make a template and have on made up and then post the pics of it. I would like to see how it turns out if you do this project
OG Fabricator
1 Post
Re: b-series trany adaptors for RWD trany. (tucker3113)
i'd love to work on a project like this, but the crappy part is i'd need to have the combo infront of me to build it and i live all the way up here where we all live in igloos and work as lumberjacks.
what about instead of going with a b series, go with a miata driveline?
Why not put a sr20 in it... if your going to make a bastard child might as well stuff a big block in it.
Re: b-series trany adaptors for RWD trany. (blackwagon)
Pretty much screwed with the reverse rotation, but I know g-force makes a G5 Reverse Rotation Honda Box..but be ready to fork over $7000+ for the trans alone.
Later
Randy
Later
Randy
or use a h powerplant & a gen III surpa tranny...a lit machining the plate and you have a nice setup :-)...then just use a custom gear set...any way you look at it its going to be costly...
U can use a miata tranny. All of the bolt holes but one will line up, need to get straight gear so u can spin the tranny backwards. Few other minor things. friend of mine did it in his coupe.
Re: (sewell94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sewell94 »</TD></TR><TR><TD CLASS="quote">U can use a miata tranny. All of the bolt holes but one will line up, need to get straight gear so u can spin the tranny backwards. Few other minor things. friend of mine did it in his coupe. </TD></TR></TABLE>
get some pics and more info
Re: (hulkhb)
b16 honda engines turn backwards from any thing else, so if you get a straight cut gear tranny with an adaptor plate it will work all you have to do is flip the rearend over. and the car will go forward when it is in first.
Re: (hulkhb)
I'll give him a call, see if he has any. He done a tons of stuff with his car, he has to much time or something. Started out as a regular coupe. Then was swapped with a b16. Then made RHD, then front engine rwd, now its mid engine rwd. From what i was told he actually help designed some of the hasport mounts, and actually was flown in to finish the falken drift cars at the last minute a few years back. **** he does is amazing. I'm kinda curious to if he still has the miata tranny still.
Re: (kb58)
i know about the SR20DET but ive already had one of those, and sold it, thats too easy, want to make it hard now, and yeah i know that a b16 spins backwords!
Re: (solpower)
If you want it a little more difficult, try the VG30 V6! It's been done but isn't an easy swap from what I understand.
(check out my avatar)
Wes
Wes
Re: (Wes V)
dont want a vg30 too heavy, have seen it done b4 also, i want to use a b series because of vtec, it might be overated but i like it, its not the same without it after haveng it.
Re: (VenGeanceDrag)
why dont you just use a Kseries, and mount a s2000 transmission on it... vtec and RWD, problem solved... i think they just bolt up... i might have read that on another post. That might be a fun time to do all the fab work and make it fit and it is going to be faster than a b16.
Good luck
-Drew
Good luck
-Drew
Suspetise...
1 Post
Re: (Electron_LS-Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec »</TD></TR><TR><TD CLASS="quote">why dont you just use a Kseries, and mount a s2000 transmission on it... vtec and RWD, problem solved... i think they just bolt up... i might have read that on another post. That might be a fun time to do all the fab work and make it fit and it is going to be faster than a b16.
Good luck
-Drew</TD></TR></TABLE>
They don't. Someone claimed they did, and then when another someone actually tried it, it was completely off. It might still be fun, but wouldn't be easier than a B16, except possibly for the direction of engine rotation.
Good luck
Banned
Re: (sscguy)
Joe mocked up a G-Force RWD transmission to the H22 engine..
Bolted right up. He is actually considering when Party Time is done to build a full tube EP with K engine on it.
Ricky
Ricky
Suspetise...
1 Post
Re: (af-performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by af-performance »</TD></TR><TR><TD CLASS="quote">He is actually considering when Party Time is done to build a full tube EP with K engine on it.</TD></TR></TABLE>
:Blort:
Pics will be required if he does that
:Blort:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by af-performance »</TD></TR><TR><TD CLASS="quote">I forget who he said told him it would work, but apparently another car thats being built actually has the h22 and gforce tranny.</TD></TR></TABLE>
that would be G-Force owners son mike.
honda for sale
im just going to go with the S2K motor and trans, and i also have an 86 accord for sale real nice car its just lowered toooooo much, needs springs, runs good 2000
530-872-2525
530-872-2525
revvin9k
07-28-2005 04:21 PM
