90-93 integra spare tire area fuel cell? What fuel cell have you used?
Old 02-02-2008, 10:07 PM
MidShipCivic's Avatar
Default 90-93 integra spare tire area fuel cell? What fuel cell have you used?
I'm looking to put a cell here what modifications have you done to the chassis and brand have you used for a fuel cell ?
Old 02-03-2008, 03:45 AM
xxbulaxx's Avatar
Default Re: 90-93 integra spare tire area fuel cell? What fuel cell have you used? (MidShipCivic)
I have an RCI 8-gallon cell that's going in my Mustang. The spare tire area should be about the same size as the teg's, but I think the mustang's is deeper. But the cell fits perfect and allows room on the front and rear of it to mount the straps.
The only 'fabrication' needed is cutting a hole where the sump will stick through the floor. I'm probably going to weld in a sheetmetal sump to the floor to cover and protect the cells plastic sump that sticks through.
Old 02-04-2008, 06:45 AM
Andy R's Avatar
Whats the purpose of the car?
Drag: you'll only need something small and usually closer to the engine.
RR/AutoX: 8-15g with either slopped sump or intank sump box so you don't fuel starve.
Street: need something to handle medium length travel 12-15 gallon
I personally have a ATL 12 gallon bladder/steel box setup with intank surge tank for RR purposes. The fill plate has rollover protection as well. Mounted in a CRX near stock location with sheet metal cut out so cell drops in from incar. Steel square tubes integrated into roll cage to mount the cell.
Old 02-04-2008, 10:07 AM
Lousy Beans's Avatar
Default Re: 90-93 integra spare tire area fuel cell? What fuel cell have you used? (Andy R)
That sounds pretty similar to what i'm planning... You wouldn't happen to have any pics, would you?
Old 02-04-2008, 03:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andy R &raquo;</TD></TR><TR><TD CLASS="quote">Whats the purpose of the car?
Street
I personally have a ATL 12 gallon bladder/steel box setup with intank surge tank for RR purposes. The fill plate has rollover protection as well. Mounted in a CRX near stock location with sheet metal cut out so cell drops in from incar. Steel square tubes integrated into roll cage to mount the cell.</TD></TR></TABLE>
Pictures of this setup please.
Old 02-05-2008, 07:35 AM
Andy R's Avatar
The setup is not completed, but I do have the cage finished with the mounting tubes run for the tank. Unfortunately I don't have any pictures taken, and the car is in storage for the winter. The tank is a 15g ATL Super Cell 100 Series with drop in 3-door surge tank and intank fuel pump. Filter at the tank and at the rail. Fill and return lines are either -8AN braided or 1/2" SS hard line. External inline Walbro 255 at the tank as well. The car will be between 275-400 hp depending on boost levels on a gt30r turbo'd B16a. Fun weekend car that will see some open road course racing.
I'll work on getting some pictures.
Old 02-05-2008, 01:20 PM
Bailhatch's Avatar
build a round one
Old 02-12-2008, 07:46 AM
ComeOnKip's Avatar
Location: Where the wild things are in, NY, United States of America
You might be interested in an ATL well cell, its designed to fit in a spare tire well. They come in an 8 and 12 gallon size.... iirc the 12 gallon is the only one they can fit with a surge box / flapper door set up.
Nice piece.
Old 02-12-2008, 07:59 AM
OG Fabricator
weiRtech's Avatar
i have a triangle engineering one (10 gal) i ran in my crx, which is probably close to the same, if not smaller. it has a foam baffle in it. i'd sell it if someone wanted it.
LS-VTEC-TURBO-EF9
05-06-2009 12:39 PM
sheepey
09-11-2006 07:30 PM
FWDrag
01-28-2005 08:58 AM
K20EG
11-04-2003 06:49 AM
Reid
09-14-2002 10:26 PM
Quick Reply: 90-93 integra spare tire area fuel cell? What fuel cell have you used?
