5052 aluminum
Old 03-31-2009, 04:37 PM
Adriano's Avatar
Default 5052 aluminum
Would 5052 aluminum be good for intercooler end tanks? I have welded 5052 before with ease. It's half the price at my local supplier. I'm talking about .125 thickness.
Thanks
Adriano
Old 03-31-2009, 05:06 PM
ROTARY's Avatar
Default Re: 5052 aluminum
Ive used it for making endtanks for intercoolers and radiators, its good.. easier to cut and makes less noise when cutting with a band saw.
Old 03-31-2009, 05:15 PM
Adriano's Avatar
Thanks. That's what I noticed too, it cuts really easy.
Adriano
Old 03-31-2009, 06:50 PM
dave@passenger's Avatar
Adriano
5052 will be fine for intercooler end tanks, it will form a lot nicer than 6061 as well.
Old 03-31-2009, 09:21 PM
GTibunny16v's Avatar
I use 5052 for almost everything. I only use 6061 if its cheaper or I cant find what I need in 5052.
Old 04-02-2009, 01:11 AM
awill4x4's Avatar
It depends on how tight a bend radius your bender does. It's tougher than 5005 and can crack along the bend if its a tight radius and if you're bending along the rolled grain line rather than across it.
I much prefer to use 5005, I find it's much easier to work with.
Regards Andrew from Oz.
Old 04-08-2009, 11:51 PM
levelzero's Avatar
It's actually a better choice then 6061 as it is more corrosion resistant. 5052 is considered a marine grade.
a267mm
Welding / Fabrication
11-26-2014 01:26 PM
1junkycivic
03-11-2009 05:29 PM
HiAssHell
11-17-2005 10:24 AM
cock head
09-23-2005 09:51 AM
.RTErnie
09-27-2004 11:11 PM
Quick Reply: 5052 aluminum
