1000HP BSERIES 3D build of civic hatch solidworks cad highly detailed models
#28
Re: 1000HP BSERIES 3D build of civic hatch solidworks cad highly detailed models
I work everyday in solidworks (and use to teach it at the university) and i goes much faster than autocad like the op said.
FYI, if you have a student email address ALL! of the Autodesk products are free including Inventor (similar to Solidworks), simulation stuff and they are all full versions. Solidwokrs is $100 for the student version alone.
Free Student Software Downloads | Autodesk Education Community
I need to learn some of this 3D design for my CNC and not sure what to use. Or how to learn
I can do 2d design decently well
#29
Solidworks is far more powerful than fusion but for the price Fusion is the way to go. I know here at work we pay $1500/yr for a solidworks subscription. You also have to pay $500 to maintain your subscription meaning if you have solidworks for a year and don't resubscribe the following year, it will cost you $500 the next time you want to update your software. However the solidworks licence is perpetual, you pay for it once and have it forever unlike Fusion.
on the cam side, HSMworks (for the basic version) is free and integrates into solidworks and inventor...fusion has its own version.
I dont think the OP is going to share his model
#30
That is some seriously bad *** work!!! I used to play with autocad back in HS but never got into anything like that! very very nice!!!!
#31
cant share this " highly classified information" yet
please post some pics of your 3d models too..
#32
I just want a dummy (all internals/cavities removed) model of the intake, block, head and tranny so i can do fit up in my model. Can you do that if i keep it under wraps?
models attached
models attached
#33
my transmission is not that accurate though.. i will try to measure the correct specs when i get my hands on it.
i will try to make a simple version and a stock intake manifold too
#38
#40
#42
I live under a rock
As an engineer - I can appreciate the amount of time this took.
Great job man.
Do a prelude! hahah....
Getting those sweeps and complex surfaces to line up and blend is HARD work. Especially to get it dimensionally correct!
Great job man.
#43
check out my latest work
I added a race radiator and a highly detailed spal fan!
more parts to come!
more parts to come!
#44
check out my recently added wiper cowl.
dimensions are accurate
next up hood mechanism
#48
Hello,
I am looking for the cad 3D model files for these great cad 3D models.
I am trying to 3d print a working model of a B18, K20, or D16 with all working and scaled parts.
I can scale them down to print on my printer.
Any help would be greatly appreciated.
Thank you,
Terry
Thank you,
Terry
#49
check out my build it runs 7's all day everyday!
It has a sleeved B18c engine block
BME rods
81mm pistons
golden eagle crankshaft (87.2mm stroke)
b series head
b series valve cover
vtec solenoid
90mm throttle body
K-series coil on plug
skunk2 ultra race manifold with 2 liter spacer
b series transmission
water to air intercooler
front suspension components (camber, cross member,lower control arms, spindles,disc brakes, axles, cv boots,shocks,steering rack,hub )
Belak front and rear wheels
MH slicks
intermediate shaft
power-steering brackets
head lights
precision 7285 t4 turbo
tial mvr 44 wastegate
exhaust manifold
t4 divided turbo flange
ID2000 fuel injectors
AN10 AN8 AN6 weld bungs
skunk2 fuel rail
engine mounts
v-band clamps
MAC boost control solenoid
civic eg chassis
1400 hp air to air intercooler
timing belt
b18c timing belt
crankshaft pulley
waterpump
custom race radiator with 16 an fittings
spal fan
body surfacing (hood, fender,etc)
side mirrors
wiper cowl
alternator assembly
brake master assembly
rear trailing arm assembly (with bushings and linkakes
dimensions are accurate because it came from a real civic eg hatch.
i measured the dimensions my self from actual head gaskets,manifold gaskets, etc..
I also have a workshop manual for a 92-95 civic
BME rods
81mm pistons
b series head
vtec solenoid
90mm throttle body
MH slicks
intermediate shaft
head lights
exhaust manifold
skunk2 fuel rail
engine mounts
v-band clamps
civic eg chassis
timing belt
b18c timing belt
crankshaft pulley
waterpump
spal fan
side mirrors
wiper cowl
alternator assembly
#50
You can 3D scan it using your phone ; ) used 123catch that Autodesk has in app form.
the problem i had with doing it was that it created too many surfaces so once it came into solidworks it was a HUGE file. Now that my full engine is built up, i may try to rescan and import.
