1000HP BSERIES 3D build of civic hatch solidworks cad highly detailed models
check out my build it runs 7's all day everyday!
It has a sleeved B18c engine block
BME rods
81mm pistons
golden eagle crankshaft (87.2mm stroke)
b series head
b series valve cover
vtec solenoid
90mm throttle body
K-series coil on plug
skunk2 ultra race manifold with 2 liter spacer
b series transmission
water to air intercooler
front suspension components (camber, cross member,lower control arms, spindles,disc brakes, axles, cv boots,shocks,steering rack,hub )
Belak front and rear wheels
MH slicks
intermediate shaft
power-steering brackets
head lights
precision 7285 t4 turbo
tial mvr 44 wastegate
exhaust manifold
t4 divided turbo flange
ID2000 fuel injectors
AN10 AN8 AN6 weld bungs
skunk2 fuel rail
engine mounts
v-band clamps
MAC boost control solenoid
civic eg chassis
1400 hp air to air intercooler
timing belt
b18c timing belt
crankshaft pulley
waterpump
custom race radiator with 16 an fittings
spal fan
body surfacing (hood, fender,etc)
side mirrors
wiper cowl
alternator assembly
brake master assembly
rear trailing arm assembly (with bushings and linkakes
dimensions are accurate because it came from a real civic eg hatch.
i measured the dimensions my self from actual head gaskets,manifold gaskets, etc..
I also have a workshop manual for a 92-95 civic
BME rods
81mm pistons
b series head
vtec solenoid
90mm throttle body
MH slicks
intermediate shaft
head lights
exhaust manifold
skunk2 fuel rail
engine mounts
v-band clamps
civic eg chassis
timing belt
b18c timing belt
crankshaft pulley
waterpump
spal fan
side mirrors
wiper cowl
alternator assembly
Re: 1000HP BSERIES 3D build of civic hatch solidworks cad highly detailed models
Badass. I've been wanting to do something like this for years but just never have the time to even start. Cool stuff.
You can find many of the body dimensions (especially chassis pickups and such) if you get your hands on a HELM body repair manual.
I'd call you a nerd if I weren't soo f'n impressed.
In for updates.
In for updates.
.likes trains
Holy ****. SOOOOOOOOOO awesome!
So what did you use to reverse engineer everything?
Re: CAD engine drawings??
I could probably do some CAD on the s2000 parts
Re: SolidWorks B Series Turbo System
Re: B16, B18, B20 CAD Model
Dude awesome! Can you share the files? it would help a ton getting the rest of my body work done! My model is so lonely with out an engine.
I work everyday in solidworks (and use to teach it at the university) and i goes much faster than autocad like the op said.
FYI, if you have a student email address ALL! of the Autodesk products are free including Inventor (similar to Solidworks), simulation stuff and they are all full versions. Solidwokrs is $100 for the student version alone.
Free Student Software Downloads | Autodesk Education Community
