FL 1985 Toyota Corolla AE86 SR5 Beams 3SGE 6 Speed
Thanks for looking at my ad
Car is on ebay now with autocheck verifying no accidents and 2 owners :-)
http://cgi.ebay.com/ebaymotors/Toyot...item1c2e8243bb
Contact: Text 954 401 987(two) or email gcarre23@hotmail.com
Hello Folks. I never wanted to have to sell my car, but to make it short and sweet, my girlfriend and I are expecting a baby and my focus in life has changed over the last couple of months. The ae86 has to go :-(
1985 Toyota Corolla SR-5 - Clean Clear Title
Original Paint
Original Interior
No Cracks In Dash
Super Clean Inside and Out - No Accidents
I am the 2nd Owner for over 8 years
Asking $13.5k - Shipping Inside and Outside of the USA available
The drivetrain swap was done professionally and the motor is wired up to look and operate like factory using the factory ECU, Harness, even the ECU Box. The car starts right up every time, functions flawlessly, sounds awesome and turns heads / breaks necks. No oil leaks, no smoke. If you know these cars the pictures and parts list speak volumes for the vehicle. There is no other corolla like this in the USA.
Body-
Original Paint with Original South Eastern Toyota Dealer Association "SS Coupe" stripe package - Dealer Installed when new.
Complete JDM Zenki Front End - All Purchased New OEM
Zenki JDM Front Bumper
Zenki JDM Front Lip
Lights / Emblem / Brackets / Grill (Rare - Discontinued)
Complete JDM Zenki Rear End
Zenki JDM Bumper (Used - Clean - Discontinued)
New OEM brackets
Kouki GTS Trunk garnish
Zenki JDM Smoked Tail lights (Clean - No Cracks)
Other
TRD N2 Mirrors (Rare - Clean - Purchased New)
Carbon Fiber Hood (Clean - No Cracks - No Fade)
Carbon Head Light Covers (Clean - No Cracks - No Fade)
HID lights
New OEM Rear Quarter Window Metal/Rubber Moldings
Suspension- FRONT
Custom Coil Over (Shortened Strut Casing w/ strut spacer))
350 lb springs
KYB AGX (sw20)
New OEM Control Arms with Urethane bushing
Megan Tension Rod
Megan Outter Tie Rod
Megan Inner tie rod
Tein camber plates
Strut Tower Bar
Tanabe Sway Bar
Custom Wilwood 4piston brakes (Big - only fit inside TE37 wheels)
UEO bomber bar
UEO fender braces
OEM Manual Rack + OEM Manual Column
Quaife Quick Steer Manual Rack Gear (Rare)
New OEM steering rack bushings
Suspension - REAR
1980 Supra Axle 7.5 inch - Completely Rebuilt End to End
Eneos Fluid
New Alxle Bearings and Seals
New Diff Carrier Bearings
Supra MK2 Clutch LSD with Weir Performance Rebuild Kit + Solid Pinion Spacer
TRD Springs 4.2kg
KYB AGX (Camaro)
Tanabe Sway Bar
TCS Strut Tower Bar
Custom Traction Brackets Welded
Custom OEM adjustable lower control arms
Complete urethane bushings
Custom Panhard adjustable with heim joints
Drivetrain-
Toyota Altezza RS200 3SGE Beams 4th Generation Motor - 210 HP - 11:1 Compression - 8k rpm redline
Toyota Altezza RS200 6Speed Cross Ratio Transmission
Factory ECU + Engine Harness
Low Mileage Swap with new timing belt service and recent clutch
Custom Steel Driveshaft - Balanced
Custom Front Subframe + Aluminum Trans Mount
Custom Mishimoto Radiator + Fan + Shroud
Custom Intake
Custom Fuel System @ 62psi (Same fuel system from my old 400HP setup)
Custom Secondary Exhaust Runners to 2.5 Mandrel Bent Over Diff Exhaust with
Rare Nissan - Impul Super Muffler 60mm Full Stainless Muffler
Interior-
GTS Cluster
NRG Harness Bar
Gforce Driver Harness and NRG Passenger Harness
NRG Quick release
Custom OEM Toyota Altezza Stainless Pedals
Titanium Shift ****
OEM MOMO Honda Steering Wheel with TRD horn button
Carbon Fiber Shifter Console
Complete Clean Interior
Wheels/Tires-
15x7 Volk TE37 in Magnesium Blue
Volk Center Caps
Project Kics Composite Lugs
Falken Azenis 205-50-15
Pics-
Original Paint
Original Interior
No Cracks In Dash
Body-
Zenki JDM Front Lip
New OEM brackets
Other
HID lights
Suspension- FRONT
350 lb springs
KYB AGX (sw20)
Megan Tension Rod
Megan Inner tie rod
Tein camber plates
Strut Tower Bar
Tanabe Sway Bar
UEO bomber bar
UEO fender braces
Suspension - REAR
Eneos Fluid
TRD Springs 4.2kg
KYB AGX (Camaro)
Tanabe Sway Bar
TCS Strut Tower Bar
Drivetrain-
Custom Intake
Interior-
GTS Cluster
NRG Harness Bar
NRG Quick release
Titanium Shift ****
Wheels/Tires-
Volk Center Caps
Pics-
23psi4age
01-02-2013 04:54 PM
allblacksrt4
07-16-2007 12:43 PM
