Won't go into Reverse
So I just rebuilt it. Hooked up a spare linkage and it wont go into reverse.
I know that reverse is different and usually a bitch even in the stock transmission. Usually have to rev it and try a few time before it goes in.
Problem is, I cant get it to move at all. I can go into 1-5 (although with a little jiggling) I am guessing its not *Like butter* because it is off and there is no oil in it.
But still reverse isn't moving and the fork doesnt even Budge. Here attached are some pictures. If you need to see anything let me know.
I really need to get this figured out ASAP
Thanks
Side Note: The 5th Gear hub keeps wanting to sneak up off the mainshaft and I keep tapping it down. Wondering if this will happen in the case.
PS: This reverse thing on the right side just sits there limp dick and doesnt seem to do anything. Did I install this wrong? And the Back of the big one has a spring loaded arm but it doesnt seem to do anything either.. Hmm Let me know
Thanks
