Whiny 2000 SI S4C - Honda-Tech
Whiny 2000 SI S4C
Old 03-13-2017, 08:27 AM   #1
WhiteSlips's Avatar
Default Whiny 2000 SI S4C
I have had some transmission issues in the last couple years and just want to get some input. While my car was down I had all of the worn synchros and shift sleeves replaced and at the same time we did diff bearings and the bearings on either end of the main shaft and countershaft. The transmission whined pretty bad before we did any of that work and we assumed it was the diff bearings. We replaced those with OEM and it got quieter, but was still present. Now that I've put a few hundred miles on the "rebuilt" transmission the whining is louder than it was before the new diff bearings were installed. It does it in every gear, but loudest in 1st and gets quieter as you work your way up through the gears. I do remember there being a good amount of metal built up on the magnet when we first opened the case and I wasn't sure if that was debris from the bad bearings we replaced or gear material. It has the stock 2000SI open diff in it.
I am leaning towards it being the gears in the diff itself, but wanted to see what people thought or had any tips on how to troubleshoot it before I start ordering parts.
WhiteSlips is offline   Reply With Quote
Old 03-15-2017, 12:04 PM   #2
Aquafina's Avatar
Default Re: Whiny 2000 SI S4C
Were the shafts fully disassembled and everything properly cleaned?
How did the gear needle bearings look?
How did the collars and ID of the rotating gears look (still have the cross hatch?)?
How did the gear teeth look? Were they worn?
The Helms manual lists all the specs for ID's and OD's and gives an okay example of what the gear teeth should look like shape wise.
Aquafina is offline   Reply With Quote
Transmission gets stuck in 5th and bearing/gear noise v4lu3s Transmission & Drivetrain 2 09-10-2016 08:45 AM
Another Transmission Problem bmxkills Transmission & Drivetrain 6 02-17-2011 07:24 AM
B Series Tranny Problem bmxkills Transmission & Drivetrain 24 01-23-2011 08:12 PM
Transmission whine. Need some advice. Rooftop voter Transmission & Drivetrain 4 07-06-2010 07:16 PM
Rebuilt trans making noise Jspec_ej8 Transmission & Drivetrain 7 10-10-2009 04:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
