Where do you put the transmission fluid?
Re: Where do you put the transmission fluid?
Well...for us to answer that very thoroughly, you first have to tell us the engine you have in the vehicle, so we can instruct you on where it is.
In the space between the battery and the throttle body, look down at the axle going into the transmission. Behind the axle hub, there will be a 17mm bolt which is the FILL plug. Below that is a 3/8" ratchet bolt that is the DRAIN plug.
niceprelude
10
02-08-2009 04:20 PM
