when my car hits 40 mph, it feels like it's not in the right gear - Honda-Tech
Old 06-28-2011, 12:02 PM   #1
Icon2 when my car hits 40 mph, it feels like it's not in the right gear
When I hit 40 Mph, my car shakes (sort of like when you're hitting those little ridged parts of the road on interstates and what not) but when i let off the gas and press the gas again, it doesn't do it.. I'm hoping it's not my transmission, but I'm not sure. I've never messed with a transmission..
It's an automatic 2005 honda accord with 130k miles on it
i check my fluids regularly
and also when i have my AC on sometimes my car lags more than the other cars i've had and sometimes takes a minute before it speeds up while i'm pressing the gas
it feels like ..
when you're driving a manual car and you have it in a high gear at a low speed.... any suggestions?
Laceyfer is offline   Reply With Quote
Old 06-28-2011, 02:39 PM   #2
netfreak's Avatar
Default Re: when my car hits 40 mph, it feels like it's not in the right gear
You check the transmission fluid level with the car on, right? Also check the fluid color. If it is anything other than a clear red, could mean problems. Before I nuked my 700R4 tranny in my Chevy it had a real bad stuttering type feel. Fluid color also turned black/brown as the clutch packs were fried.
netfreak is offline   Reply With Quote
Old 06-28-2011, 03:19 PM   #3
H-T Basic Sponsor
Gearspeed-Performance's Avatar
To check fluid level in a Honda Automatic, you bring the vehicle up to operating temperature, park vehicle on a level surface and shut vehicle off...then check reading on the transmission fluid dipstick. As netfreak said...check fluid condition and odor. If fluid is dark and burnt you may have a transmission issue aside from the shaking or in addition to.
As far as the shaking..check your axles, suspension, tire condition and make sure your lug nuts are tight . A lot of the shaking issues on vehicles have a lot to do with tires believe it or not! lol So start with the easiest most obvious things to check and go from there. When checking the axles move the inboard end of the axle side to side to see if there is any differential play in the transmission. Check the axle seal area for leaks. Check those items and come back and let us know what you find. Good luck!!
__________________
Gearspeed Honda/Acura Tranmission Parts and Performance - www.gearspeedwholesale.com - 909-476-7252
*Rebuild Kits*LSD*Carbon Synchros*Gears*Final Drives*Trans building*
Gearspeed-Performance is offline   Reply With Quote
90 Honda Accord unsolvable mystery problem! psiguy Honda Accord (1990 - 2002) 29 06-26-2014 05:13 AM
Rough engine/vibration at 45mph Chelle8864 Engine Management and Tuning 4 06-21-2010 06:07 AM
Shifting Technique thread, good info. mnbv Road Racing / Autocross & Time Attack 17 10-02-2004 03:55 PM
weird vibrations esca Honda Prelude 1 09-25-2004 09:00 AM
Feels like my transmission jerks when I disengage clutch at low speeds. VTECorona Tech / Misc 2 08-25-2002 12:38 AM
Tags
2006, 40mph, car, dosent, element, feels, gas, gear, honda, press, rumbles, run, slow, speed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
