Ways to identify if your trans is a b16 or gsr - Honda-Tech
Old 04-19-2011, 10:16 AM   #1
Antilag's Avatar
Default Ways to identify if your trans is a b16 or gsr
Bense, if you would like to add this to your trans topic, it would be great.
Thanks to David from synchrotech the genius of trannies. Heres info that can really help.
I have alot of customers ask, i need a lsd but cant tell if its a b16/ls or gsr cause the sticker is ripped off.
3 ways to confirm.
#1 your ring gear. The big hole where the diff fits into. The measurements are close but different. B16 is 116.8 mm and the gsr will measure 119.8. edge to edge
#2 your ring gear face. along the oem ring gear face they both have id lines that run around on the teeth. If it has 2 id lines one top and one bottom its a B16, if it has 1 id line in the middle its a gsr.
#3 stock oem 3rd gear on the main shaft, count the teeth and double count cause they are only 1 off to differentiate the 2. If you count 24 teeth on the main shaft 3rd gear its a B16, if you have 25 teeth than its a gsr.
Hope this helps everyone.
Antilag is offline   Reply With Quote
Old 04-21-2011, 03:54 PM   #2
Default Re: Ways to identify if your trans is a b16 or gsr
Great info
05foresterxt is offline   Reply With Quote
Old 04-22-2011, 08:01 AM   #3
H-T Premium Sponsor
Synchrotech-Transmissions's Avatar
The LS FD also has 2 ID lines on the R/G with a 109.8mm hole but with a 64 tooth ring gear.
B series transmissions 1994-2001
LS: 64T (tooth) R/G 2 lines (109.8mm), 15T C/S 2 lines, 26T M/S 3rd 2 lines.
GSR: 66T R/G 1 line (116.8mm), 15T C/S 3 lines, 25T M/S 3rd 1 line.
B16 66T R/G 2 lines (109.8mm), 15T C/S 3 lines, 24T M/S 3rd no line.
__________________
Synchrotech Transmissions / MFactory R&D
Carbon Synchros - LSDs - Torco MTF - Custom Builds - Gears - FD Sets - Rebuild Kits
Tech Support: David (909) 592-5900
www.synchrotech-transmissions.com
Synchrotech-Transmissions is offline   Reply With Quote
Old 04-22-2011, 08:12 PM   #4
Who the fack changed my title?!
sh!ft's Avatar
sh!ft is offline   Reply With Quote
Old 04-28-2011, 06:44 AM   #5
MR.johnson's Avatar
good info. i should go threw some of my junk and figure out what i really have laying around.
MR.johnson is offline   Reply With Quote
Old 03-13-2017, 09:55 PM   #6
Default Isthis Gsr? Or.b16?
This GSR or B16?
Toro452 is offline   Reply With Quote
Old 03-15-2017, 06:46 AM   #7
H-T Premium Sponsor
It is a GSR (116.8 mm diameter hole and 1 ID mark in middle of tooth)
__________________
Old 03-23-2017, 03:27 AM   #8
0c00l's Avatar
Great info, this should be stickied
0c00l is offline   Reply With Quote
Ls countershaft in gsr tranny??!! SourflowEdd Transmission & Drivetrain 1 06-02-2016 08:33 AM
How to tell gsr from ls countershafts? Rooftop voter Acura Integra 2 09-23-2010 07:50 AM
B-series Mainshaft blues..F**K!! Adi Radoncic Transmission & Drivetrain 3 06-17-2009 11:38 PM
Y21 trans gears?? 1320king Transmission & Drivetrain 6 03-22-2009 10:28 AM
Differential, anyone know what diff this is? Austin Drag Racing 3 05-30-2004 09:11 AM
Tags
3rd, 64, b16, bseries, count, find, gear, gsr, have, series, teeth, tooth, tran, transmision, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
