Turning a hydro trans onto cable operated?
Hey guys, I got my B18a1 a few weeks back and have begun the build. It came with the original transmission (hydro) and I'm wondering if it's possible to use it with my cable set up. I found these brackets on ebay that supposidly convert the tranny over to cable. Has anyone ever heard of these? Good idea or bad? Thank you. Heres the link: http://m.ebay.com/itm/CIVIC-CRX-B-H-SERIES-CABLE-TO-HYDRAULIC-TRANSMISSION-TRANNY-MOUNT-BRACKET-PLATE-/252123934560?nav=SEARCH
Re: Turning a hydro trans onto cable operated?
I don't have any experience, however that thing is going to have so much play your going to hate it and most likely it won't work properly.
Another thing you can do is convert the car to hydro or switch the case to a cable big spline.
I havent used that one, but the hasport kit sucks. Spend the money and get the innovative kit. Friend of mine installed in on a f2b swap with a stage 4 clutch and it feels factory smooth. The hasport kit was so bad we couldnt even actuate the clutch and almost broke his pedal. The full mechanical conversion kits seem to be pretty poor at their job, but hybrid systems, while more expensive, work great
https://www.innovativemounts.com/Pro...ductCode=41001
H-T Premium Sponsor
I know, thats why i pointed out that with a stiff clutch it binds. A stock pressure plate it gets the job done though.
A lot of people dont realize that with a stiff clutch you need to either go full hydro or use a hybrid system
Seagull Management
Get a transmission case from a '92 - '93 Integra and put the guts from the transmission you have into it, or find a complete '92 - '93 Integra RS/LS transmission.
i am currently rebuilding a ys1 cable trans i have two of everything. if you would be interested I have a extra case that i am currently repairing where the previous owner poked a hole in it with a spider gear.
90efcvicsi23
12-04-2008 10:19 PM
jdmcrx90
05-02-2005 02:40 PM
dustin
04-01-2002 11:15 AM
