Transmission & Drivetrain Gearboxes, Differentials, Clutches
engine spins freely
Old 07-26-2009, 03:28 PM
sde780's Avatar
Default engine spins freely
i took my tranny and clutch out to swap the engine, and put it together the same way i removed it. everythings together now, but the engine spins freely with the tranny in 1st gear. wheels dont move at all. any ideas what i did wrong?
Old 07-26-2009, 04:05 PM
sde780's Avatar
Default Re: engine spins freely
I didn't use the clutch alignment tool, didn't know about it till today.
I put the flywheel on, bolted it down, then put the clutch on and bolted that down. Tranny went in without much trouble. You think it's because I didn't use the tool?
Old 07-26-2009, 04:55 PM
ej1excoupe's Avatar
u did put the pressure plate on right?
Old 07-26-2009, 05:42 PM
sde780's Avatar
Yeah pressure plate is on.
1991 civic d series cable tranny here. The clutch disk, if installed right, the side that protrudes more, what does it face, the flywheel or pressure plate? I installed it facing the pressure plate, wonder if that's reversed...
Old 07-26-2009, 07:21 PM
jjspec's Avatar
Pressure plate. Did you get the shifter rod hooked up? Is it just first or every gear?
Old 07-26-2009, 07:34 PM
sde780's Avatar
Yes rod is hooked up. It's every gear
Old 07-28-2009, 08:33 AM
sde780's Avatar
ok so i dropped it all out, then put it back together and it works. moral of the thread is, check before you swap it in
Old 07-28-2009, 12:56 PM
srmofo's Avatar
cmon.... fess up....what did you forget to install?
Old 07-28-2009, 08:33 PM
Honda Bull's Avatar
x2
In case someone does happen to use the 'search' - I know, it'll be a cold day in hell - they can possibly see your question, and what caused it. Don't leave someone actually taking the time to search hanging with an un-updated thread.
Old 07-28-2009, 08:48 PM
sde780's Avatar
I didn't forget anything. My friend said when I put the tranny together the first time the shaft might have been hitting the flywheel or PP or something, idk. But I took it apart, put it together same way as the first time (without clutch tool just center the clutch real good with the motor on its side) and then bolted it together. Works from what i can tell, haven't driven the car yet because I need a new rad
Old 07-29-2009, 04:05 AM
srmofo's Avatar
if you didnt hit the hole it wouldnt of bolted together........
...fyi..... you can use a 1/2 drive socket with a 3/8 drive extension through the center as a clutch alignment tool....its a little sloppy, but it works better than eye balling it unless your engine is out of the car and it works like a charm
Old 07-29-2009, 04:34 AM
sde780's Avatar
hmm okay im clueless then. but i took it apart and put it back the same way, it works now.
yeah my engine was out for the installling process
jlowellintegra
06-21-2011 08:13 PM
thedudefromjerz
08-01-2008 09:54 PM
1990civicsiguye
12-30-2003 06:30 AM
John
11-29-2001 07:29 PM
Quick Reply: engine spins freely
