Transmission & Drivetrain Gearboxes, Differentials, Clutches
1st Gen CRX Clutch/Brake Pedal Mount Failure
Old 05-06-2013, 05:07 PM
svenfran's Avatar
Default 1st Gen CRX Clutch/Brake Pedal Mount Failure
Word to the wise: If your clutch pedal effort is high, go ahead and lube/free up the cable at your earliest opportunity. You may not notice how much force it's taking to operate the clutch, because it just gets progressively worse. I didn't notice mine until it broke the mounting bracket for the clutch and brake pedals that mounts to the firewall under the dash. It flexed due to the excess force until it finally cracked and broke. I was able to fix it, by taking it off and bolting on a metal reinforcement, but lubing the cable earlier would have saved a lot of labor. Good luck. Feel free to PM or reply if you have questions about the earliest CRX models. Mine is an 84 first year model that I've owned since new. Svenfran
quik89
12
01-18-2007 11:00 PM
EF9 JAMS!!!
10-19-2005 11:16 AM
crxgator
12
03-21-2004 09:30 AM
iridebiketrials
12-05-2003 10:05 AM
LSBeast
04-16-2002 08:18 AM
Quick Reply: 1st Gen CRX Clutch/Brake Pedal Mount Failure
