Transmission & Drivetrain Gearboxes, Differentials, Clutches
tranny squeal! what is it???
Old 10-19-2009, 09:23 AM
RG400SmartTowel's Avatar
Default tranny squeal! what is it???
i have gsr trans and when i put it in first and begin to take off, the tranny makes this loud squeal noise. it only happens sometimes at the right friction point. it happens on hills too. The noise is very audible. I just recently replaced my clutch. I already have a bad input shaft bearing but i never got around to replace it. The noise from the input shaft bearing was really loud at first with the clutch engaged. but as i drove more and more the noise is hard to hear with the clutch engaged. when is disengaged there is no sound. can you guys help me out?
Old 10-19-2009, 12:07 PM
I'm not Rick!
rick_rabies's Avatar
Default Re: tranny squeal! what is it???
sounds like that shaft. you sound smart but i have to throw in this question. you have oil in it right? the right kind and amount?
Old 10-19-2009, 04:00 PM
Aquafina's Avatar
ISB exploded and is now wearing the mainshaft.
Old 10-22-2009, 05:56 PM
is it better to buy a new tranny or keep this one but replace the bearing since the bearing exploded. I dont hear the input shaft bearing noise like i used to hear it any more. its just quiet now when i have the clutch engaged. but when im decelerating i still hear a noise.
Old 10-22-2009, 06:18 PM
Aquafina's Avatar
Split the case, pull the ISB/seal out. Inspect the clutch housing under the ISB. If it has been chewed up, get a new trans. Measure the mainshaft and it its under the service limit, get a new trans.
diamondstarsforever
06-15-2009 09:50 AM
Jdm_Eg686
15
10-09-2007 12:19 PM
Emshhh
11
02-02-2005 11:10 PM
B18B EK
02-20-2004 07:19 PM
not so civic
01-30-2002 04:21 PM
Quick Reply: tranny squeal! what is it???
