Transmission & Drivetrain Gearboxes, Differentials, Clutches
torque converter + speed sensor both bad?
Old 04-09-2009, 05:25 PM
oblivion2kx's Avatar
Default torque converter + speed sensor both bad?
Ok so I have a 96 accord Ex vtec with auto tranny.
Back in november my trans flared after shifting gears and then one day on the highway a CEL came on and it went to redline and hardly shifted from second after that. I ended up disconnecting the battery for a half hour then connecting it. CEL is off but it shifts into second gear at 5k rpm. I decided to do a trans fluid change, but before I did that I jacked up the front end to check for leaks.. no leaks. Then I put it back down and it drove fine, shifted normally. I let it sit for a day, started shifting erratically. I changed the trans fluid with atf-z1 3 quarts and cleaned the magnetic plug. Shifted beautifully and I decided to take it on a test drive.....
After about 20 min, it started to act up slowly.. then at 73mph and 3450 rpm CEL kicks on and it gets worse. I pulled two codes, P0740 and P0715 regarding the torque converter and speed sensor..
Can both of these go bad at the same time? Would it even be worth replacing individually vs new tranny?
I pulled 2 codes
P0740 - Torque converter clutch soleniod circuit
Freeze Frame Data:
Fuel Sys 1: CL
Calc Load%: 80.7
ECT F: 197
STFT B1%: -3.9
LTFT B1%: 0.7
MAP: 24.2
ENG RPM: 3207
SPEED: 73
IAT F: 100
TPS%: 28.2
Second code P0715
Turbine/Input Shaft Speed sensor circuit
Old 04-10-2009, 03:12 PM
Default Re: torque converter + speed sensor both bad?
bump
Eric McBride
01-10-2018 01:54 AM
denraweb
04-14-2011 03:44 AM
oblivion2kx
04-09-2009 06:21 PM
HondaAllDay
04-04-2009 10:43 PM
Quick Reply: torque converter + speed sensor both bad?
