swap kit flywheel
swap kit flywheel
i have a h22a in my 97 civic with a grs 5 speed trans and i have herd there is only one company that makes flywheels for this swap and that is evloution can anyone tell me different
Re: swap kit flywheel
sorry for the wait im really busy with my job i have a 97 civic si with a h22a and a acura gsx 5 speed tranny i was replacing the clutch and found that when i pulled the tranny out i need a new fly wheel two ordered one from fidanza flywheel for a h22 and it was much bigger than the one i already had so i was lost at that point then sent it back and ordered one for a b series tranny and it didnt fit either
Your inbox is full
What H2B kit do you have? Some of them will use a spacer to adapt a certain flywheel to work and Evolution makes their flywheel to work with their kit. Find out which one you have so you know what application you can use.
Here are a couple kit examples:
http://www.quartersportsdrag.com/Kit_Contents.html
http://evoindusa.com/evoauto1/index....products_id=19
Thanks I have a spacer plate between the motor and bell housing of my tranny its just a plate that lines up holes for the bell housing studs to line up to the flywheel I think was a be series with a h series bolt pattern
bboylito
12-14-2004 09:05 PM
