S20 bench shifting and sleeve question - Honda-Tech
Old 03-06-2017, 04:19 PM   #1
Default S20 bench shifting and sleeve question
I have my entire shifter assembly hooked to the trans off the car and can shift into all gears even with the case off - but i only see the main shaft changing gears with the case OFF with no gear hangups..(it changes through all gears smoothly with case on as well) Does the case need to be on for the countershaft to shift as well?
Do the synchro sleeves always have some side to side play when the shift fork assembly isn't on them?
Everything checks out clearance wise, ive gone over it over and over; I'm just curious about these 2 things.
corpsebesideme is offline   Reply With Quote
Old 03-09-2017, 09:09 AM   #2
Aquafina's Avatar
Default Re: S20 bench shifting and sleeve question
It can't be properly tested with the case off, it has to be on.
Define side to side play, it could mean a number of things so clarification will help.
Aquafina is offline   Reply With Quote
Old 03-10-2017, 12:07 PM   #3
Sorry- i meant up and down and its only on one of em- It stays in place in 4th or 5th once put in its place but it seems very loose.
All i should worry about, bench shifting wise, is that it smoothly shifts into all gears? Ive read people cant get into reverse or 5th but i am using my actual shift linkage so is that why its easier? (this was before i took trans apart it shifted into all gears fine; i just don't know the mileage so I'm changing bearings and seals)
Old 03-15-2017, 12:10 PM   #4
Aquafina's Avatar
Some play is normal. Without the shift fork controlling the slider, it will have the area between the synchro springs + synchro clearance for free movement. Once it is engaged over the synchro spring it will have a small amount of play if the spring is in good condition. The S20 uses internal detents so even with the case off once it is in gear it should stay in that position.
Bench testing it should shift into all gears (even without a linkage) and spin freely in every gear with no strange noises.
Old 03-19-2017, 01:58 AM   #5
Aqua did you see the video link i attached? that's not too much play on the 4-5 slider? seems excessive.
Do you change the friction dampers every build? and the locknut 22mm?
Old 03-19-2017, 02:42 AM   #6
Aquafina's Avatar
That is normal without the shafts and forks installed in the case. I change the friction dampers if they are damaged or hardened. Lock nut gets changed if the old detent will damage the countershaft threads or if the old detent lines up here the new one needs to be.
Old 03-20-2017, 01:57 AM   #7
Thanks , good to know !
Any way to remove the countershaft lower case bearing without a slide hammer? (I've searched online everywhere) I don't mind damaging the plastic oil plate piece under it, as i can get a new one for 3 bucks. This is the only thing holding me back from starting the rebuild. Took DAYS of cleaning out the cases spotlessly.
Old 03-21-2017, 04:59 AM   #8
Aquafina's Avatar
I use a Snap-On blind hole puller. Renting a slide hammer is much cheaper.
Old 03-27-2017, 07:11 PM   #9
Aqua- i have a 93 clutch fork and a 97- the 93 is beat up bad where the bearing mounts to its ends, so i wanna use the 97, which is exact in size, but the spring clip in it goes in upside down compared to the 93 fork- i test fitted this and it doesnt seem to matter but i do not have a throwout bearing yet to fully test- does it matter? will this 97 spring and fork work fine for the 93 trans? its in stronger spring condition than the 93 of course too.
Old 03-28-2017, 08:50 AM   #10
Aquafina's Avatar
They are the same. If there is any wear or cracks on the fork order a new one. It's not very common, but they can fail in pretty spectacular fashion.
B-series transmission teardown/rebuild tutorial Honda Bull Transmission & Drivetrain 329 07-07-2016 06:34 PM
GSR Trans. Issue 5th Pops Out (Oil level is finel) Fantastic420 Tech / Misc 1 04-01-2016 12:45 AM
Need opinions on GSR Transmission issue. Fantastic420 Transmission & Drivetrain 0 03-31-2016 01:15 PM
SpeedFactory-Modified Shift Change Holder Assembly for B Series SpeedFactoryRacing Performance 164 10-18-2013 07:52 AM
shift change assembly and interlock problem??? 91CRX-T Transmission & Drivetrain 3 06-21-2011 12:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
