Transmission & Drivetrain Gearboxes, Differentials, Clutches
No reverse after rebuild?
Old 05-08-2011, 10:23 PM
Davidss's Avatar
Default No reverse after rebuild?
So I have 2 D16A6 transmissions both with bad input shaft bearings.
Transmission 1:
Pulled it apart and replaced the ISB. Put it back together and the transmission (sitting on the shelf) will go into all gears except for reverse. I took the case back apart and now magically it will shift into reverse. When you shift to reverse the 5th gear shift fork wants to go backwards into the bearing at the end of the mainshaft. So it seems to shift fine if the case is apart but put it back together and it doesn't work.
I assumed I must have installed something backwards but after inspection I could not find anything so I tore apart transmission 2 for comparison.
Transmission 2:
Shifted into all gears ok. This transmission has a bad ISB. Then I took apart the case ONLY. I didn't disassemble or touch anything else. But now that the case is apart transmission 2 won't shift into reverse either. Didn't try to put the case back together and retest, too frustrated!
Any ideas?
Old 05-10-2011, 12:32 AM
Davidss's Avatar
Default Re: No reverse after rebuild?
Got it figured out I think. One of the ball bearings in the shift fork assembly was mis-installed.
Old 04-14-2012, 07:58 PM
faylo604's Avatar
I am having the exact same problem, what ball bearing on the fork are you talking about.. are you talking about the detent with the spring and bolt that holds it down? please help
Old 06-12-2013, 07:59 AM
scudman's Avatar
did this ever get resolved?
Old 06-12-2013, 08:21 AM
scudman's Avatar
what's the trick to the shifter/pawl relationship for a reverse with a torqued case?
MrMug3n
11-28-2010 02:19 PM
stevenDAtegra
12
05-03-2010 10:57 PM
itismejoshd
25
09-25-2007 05:16 AM
WONG FRIED RICE
04-17-2003 09:05 AM
Juantay19
04-02-2002 10:43 AM
Quick Reply: No reverse after rebuild?
