new clutch. car wont go in gear while running - Honda-Tech
Old 07-22-2009, 08:37 AM   #1
harker's Avatar
Default new clutch. car wont go in gear while running
ok so i just put in a compition stage 2 clutch and pressure plate also a new flywheel (b18b hydro). after i got everything together the car wont go in gear while its running. while its off it goes in all gears but a lil crunchy i geuss.. i bled the clutch the best i could. i started it in first then let off the clutch and it grabed but when i pressed the clutch back in it felt like it was still grabing a lil bit witch is the reason i cant get it in gear while its running...now the only thing i can think of is maybe i tightend the presure plate too much (is that possible) or im not getting enough pressure to fully press in the clutch with the stiffer pressure plate.
Can someone please shed some light on this for me im stressin and i really just wanna drive my baby again..i have been researching and i still am but im running out of time please help
harker is offline   Reply With Quote
Old 07-22-2009, 02:18 PM   #2
New User
Default Re: new clutch. car wont go in gear while running
It sounds like during installation one of 3 things could have happened.
1) The splines got messed up stabbing the transmission, or
2) the plate got bent itself or
3) The plate is in backwards
You could try and bleed it one more time but it sounds like the disc is hanging up and not allowing the transmission to spin freely. It doesn't sound like it is the clutch assembly itself although I do know from past experience that the quality of the competition brand does leave something to be desired.
grtperformance is offline   Reply With Quote
Old 07-22-2009, 06:38 PM   #3
Honda Bull's Avatar
1. What torque did you tighten the pressure plate bolts to? And did you torque them in an alternating, criss-cross pattern?
2. With the clutch depressed and coasting in gear, is it difficult to remove it from that gear?
3. Was the clutch fork and throwout bearing installed correctly?
4. Does the slave or master cylinder leak?
Honda Bull is offline   Reply With Quote
Old 07-22-2009, 06:59 PM   #4
mvtck's Avatar
on some after market clutch and fylwheels you need to ajust the rod on the clutch master cyl.
mvtck is offline   Reply With Quote
Old 07-23-2009, 07:18 PM   #5
5psi_eg6's Avatar
I got the same problem on my ITR. Changed the slave, changed the master, bled a couple of times and it still won't go in gear.
5psi_eg6 is offline   Reply With Quote
Old 07-27-2009, 05:25 AM   #6
gettin it's Avatar
You need to adjust the clutch pedal. Under the dash on the pedal up top. Not sure whats it called, but i had the same problem awhile back and did that.
gettin it is offline   Reply With Quote
Old 07-27-2009, 07:10 AM   #7
Agreed. I'm about 90% sure all you need to do is a clutch pedal adjustment, acutally just had a 01 ITR in here with the same problem kid did the clutch himself and clutch needed adjustment.
TheAsian is offline   Reply With Quote
Old 07-28-2009, 05:42 PM   #8
harker's Avatar
ok well i took the tranny off again checked every thing and re torqued the the pressure plate to 19ft lbs still the same problem.. can anyone walk me threw the whole adjusting the peddel .. im sorry for being a pain in the *** but during taking the tranny off the second time my starter went and now im about to cry.... lol i just want to beat my Ls im going into withdrall
Old 07-28-2009, 09:32 PM   #9
Honda Bull's Avatar
Well. I only ever adjust mine in order to have the clutch engage where I want it through the range of motion of the pedal.
Off the top of my head, take a gander under the dash where the clutch pedal is. The master cylinder rod will branch between the firewall and the pedal, where it is connected via a fork, cylindrical pin through the fork, and cotter pin to keep the pin stationary. The should be a 12mm nut between the fork and the actual rod that is threaded and can spin. Loosen the 12mm nut and spin the rod whichever way you may need it to go. Re-tighten the nut and depress the clutch to see how it feels to determine if more adjustment is needed.
In making this change, you may also need to adjust where the pedal stop is located as well. Which is a sensor you'll see up there that lies between the steering wheel and clutch pedal.
Old 07-31-2009, 09:55 AM   #10
Solbros Owns Me
Evs-One's Avatar
Like above, lengthen the clutch master cylinder push rod...only do it 2-3 turns max, and re-test.
Evs-One is offline   Reply With Quote
Old 08-02-2009, 10:00 AM   #11
harker's Avatar
i tried... i dont know if im doing somethin wrong or what. i turned it to the right 2-3 times (is that what i should have done?) . its just dont feel right. it feels like a stock beat clutch. There is little to no pressure. Every other stage two clutch i felt was hard to push down . i bled it till i saw nothing but a solid stream of fluid. the peddle feels about the same as the old clutch. Im thinking that it had enough pressure to push the old clutch in but not enough pressure to press in the stage two.. i dont know what elce to do
Old 08-02-2009, 03:45 PM   #12
harker's Avatar
Icon3 Re: new clutch. car wont go in gear while running
bump? anyone else had this problem? something
Old 12-10-2010, 05:13 PM   #13
Teg_Spanker's Avatar
Slave and or master cylinder don't have enough power to engage the new parts
Teg_Spanker is offline   Reply With Quote
Old 12-11-2010, 01:38 PM   #14
I was just having the same problem (replaced Clutch/PP/Flywheel and it wouldn't go into gear.) I'm also having some trans issues, but I think that's unrelated...
I replaced the slave and master and still nothing. I think your best bet is the adjustment, as mentioned. You should be turning the rod so that the resistance increases. If the resistance decreases, you're turning it the wrong way.
I think you need to turn it as if you were loosening it to make it longer...
ion_four is offline   Reply With Quote
Old 12-20-2010, 06:08 PM   #15
caiboR's Avatar
Quote:
One time I had the flywheel bolts loosen to where it stuck out to blocked the clutch from engaging with the flywheel. So since you taken off the tranny again try installing the whole clutch again.
caiboR is offline   Reply With Quote
Old 12-20-2010, 06:16 PM   #16
caiboR's Avatar
91 CRX Si - tranny won't go into gear- replaced pressure plate/throwout bearing twice :( SmobbinSi Honda CRX / EF Civic (1988 - 1991) 14 12-27-2015 08:45 AM
HELP!! clutch slipping Sr420Det Transmission & Drivetrain 3 10-16-2010 07:30 AM
clutch issues BoostedEF Honda CRX / EF Civic (1988 - 1991) 3 08-17-2006 12:45 PM
act clutch problem zbower7 Acura Integra 5 05-17-2004 08:03 PM
How to know a pressure plate is bad? USDM 4G VTEC Honda CRX / EF Civic (1988 - 1991) 6 06-20-2003 06:20 PM
Tags
93, adjust, bleed, car, civic, cluch, clutch, depressed, gear, honda, pedal, push, running, si, starts, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
